NON STEP - V BOTTOM - NOTCHED Transom - Early 2000 Cigs, Props in vs. Out
Has anyone ever tested with the props spinning in or out on a straight bottom Cigarette, with the notched Transom? or any other combinations for that matter
Do a search here. This was just talked about 2 weeks ago.
I run a '92 kevlar, straight bottom, notched transom, staggered top gun, with No. 5 drives and cleaver 4 blade 28 pitch....ran the drives turning in and turning out....
my observations:
IN- boat is faster on top end by about 2 mph, slight more bow lift, slightly less handling in tight, fast turns, less control around the docks...
OUT-boat feels more stable in fast, tight turns, better handling/control around the docks, ...
accelleration is about the same, although I felt less slip out of the hole turning out.......
My Conclusion: Unless you really need the last couple of mph on top, leave them turning out....better overall.....
my observations:
