-   -   How Fast Should I be going? (https://www.offshoreonly.com/forums/cigarette/239173-how-fast-should-i-going.html)
UrbanDisturbance 09-16-2010 11:54 AM
Originally Posted by 4195 (Post 3209461)
The props are not labbed he is runnig 5100-5200. So for you I would get the 4 blade Bravos 28p and have BBlades lab them per your specs, it will feel like a new boat!!!!!
I would be happy hitting 80+ MPH, at lease for a while.
Do you know if they are spinning in or out?
Jamie B. 09-20-2010 09:06 PM
Originally Posted by UrbanDisturbance (Post 3208842)
Is the Lipship addition carbon fiber?
I hit 71 with Full Tanks....suppose to be 220 gallons.
1 - 1 1/2 foot chop in freshwater.
Anyone else?
I have SSMIII's so I cant help with speed, but just as an fyi you have 260 gallon fuel capacity, 130 per side.
Maelstrom TG38 09-22-2010 11:20 AM
I have a 1990 top gun with custom 454's with 177 blower, about 550 Dyno HP, I hit 72 once but 70 all time in choppy water, but 68 in calm water.
I have 5PX Hydromotive 25p labbed.
Maelstrom TG38 09-22-2010 11:21 AM
Would be happy to hit 80 one day with that boat also...!!!
osen007 09-22-2010 12:42 PM
Im running 23 pitch quicksilver torrent 3 blades turning 5300 at 68 gps in flat water if it helps. I was running 25 pitch 3 blades and could only turn 4900 rpm. I have outboard props on my boat and it really lifted it out of the water at w.o.t. it feels like a 26 foot boat. When I run the 25 picth mirage props it feels like a 40 foot boat glued to the water. They guy tells me it is the cheepest way to get me with in a few miles per hour with out spending the money on labbed props. Ask for Bill Sr. 800-338-8900 Prop shop. He will blow you away with his info I think he has 100 years experiance in props. I have a 38 flat deck with 600 H.P. 468 Tall deck roller motors Dyno at 600 H.P. a peice. Bill is located in Algonac Michigan right by Sunsation
barron 09-22-2010 01:09 PM
Was getting solid 80 mph w/600's kevlar hull, cover girl cabin.:drink: Boat was a 97
osen007 09-22-2010 01:48 PM
Put it on a trailer get the tow vehicle up to 80MPH and take a picture of the speedo. Problem Solved
Maelstrom TG38 09-22-2010 03:00 PM
I have no trailer Lol !!!
No I mean with some more power for sure (but how much...)
38tg 10-02-2010 08:10 PM
92 gun
700's bravo 4 blades merc labbed 28" with extra cup 1" short drives 5400rpm's light on fuel not alot of trim 78mph. i think i can almst turn a hair bigger prop
Smitty 10-02-2010 10:36 PM
Those 5 blades are costing you speed because they lift the transom up. You need 4 blades set up for bow lift. I have been down this road before.
