-   -   Check this 28SS Cigarette in Detroit (https://www.offshoreonly.com/forums/cigarette/242729-check-28ss-cigarette-detroit.html)
28cigarettess 12-16-2011 12:25 AM
1 Attachment(s)
Originally Posted by TexomaPowerboater (Post 3571569)
If your not a grease monkey probably not a good idea to buy an old raceboat. JMHO
If you want to be a grease monkey, this would be a good boat to get broken into with. After working in that tiny bilge anything else will be a cake walk.
Yup........Engine access is tough. You need 2" diameter by 4' long arms to work in a 28's engine compartment :D.
28cigarettess 12-16-2011 12:27 AM
Originally Posted by BERUBE (Post 3572172)
Miss Cigarette has a new caretaker. I will give her the TLC that she deserves. Thanks for all the great information and advise, especially to NORTHERNOFFSHORE who gave me the little extra encourgement that i needed to pull the trigger. Lake St. Clair will be her new home for now.
Congrats and enjoy :drink:
NickOTeen 12-16-2011 09:24 AM
Congrats! One of my favorites. 28s Rock! :D
POWERPLAY J 12-16-2011 09:39 AM
Congrats! Hope to see her out there next year :)
TexomaPowerboater 12-16-2011 09:51 AM
Man............those brown stains on your transom could be an indication of transom rot. Not trying to poke at your boat, just don't want to see your boat end up at the bottom of the lake.
TexomaPowerboater 12-16-2011 09:56 AM
Originally Posted by dreamer (Post 3571815)
needs race gas and valvetrain maint every 15 hrs
plus oil change every 10
not a pleasure boat
just got off the phone with the owner who traded it to the guy in mich
:picard1:
The guy needs to do himself a favor and swap them for some stock small block 350 mags....
bigboat28 12-16-2011 12:00 PM
Congratulations on your purchase.
northernoffshore 12-16-2011 03:24 PM
not a pleasure boat
Congratulations on buying the boat !! If the cams in it now are solid rollers cams , it might be smart to switch over to Hydraulic style. You could eliminate the constant valve lash maintenance and possible bleed off some compression and get back down to 93 oct.. It can be done without removing the engine in about 4 hours,(there are cam removal holes I cut into the rear bulkhead for this) I used 480 480 230 230 cams that were not rollers and worked great. If not ,just learn how to do the valve lash and basic stuff, small blocks are pretty easy to work on once the exhaust is removed. Good luck with the boat.
BERUBE 12-17-2011 11:02 AM
Thanks again for all of the input. The survey went well, boat is dry and solid throughout and all rigging looks good as well. I was unable to sea trail yesterday as all of the docks have been pulled and it was too cold and windy. the guy I bought it from said that it ran on pump fuel so i am not to worried about the motors being too radical for me. Even if i have to put different cams in it to make it more reliable shouldn't be a problem escpecially if the motors don't have to be pulled, I did see the cam removal holes in the bulkhead but couldn't figure out what they were for, thanks again to northernoffshore for that info. I sure do like the grab rails and the fairing you made for it. I highly recommend Dennis Biel Marine Surveyors of Harrison Twp, very knowledgeable about performance boats<a href="http://www.freeimagehosting.net/c68e5"><img src="http://www.freeimagehosting.net/newuploads/c68e5.jpg"></a><a href="http://www.freeimagehosting.net/4f0a2"><img src="http://www.freeimagehosting.net/newuploads/4f0a2.jpg"></a<a href="http://www.freeimagehosting.net/95f0f"><img src="http://www.freeimagehosting.net/newuploads/95f0f.jpg"></a<a href="http://www.freeimagehosting.net/807bc"><img src="http://www.freeimagehosting.net/newuploads/807bc.jpg"></a<a href="http://www.freeimagehosting.net/d2f64"><img src="http://www.freeimagehosting.net/newuploads/d2f64.jpg"></a>
I guess I need to upgrade my membership before attaching files?
Lee 12-17-2011 11:37 AM
4 Attachment(s)
Congratulations.:drink:
BERUBE 12-17-2011 02:27 PM
thanks for linking the pictures.
28cigarettess 12-17-2011 05:00 PM
I tapped around the transom with a ball peen and it sounds solid and uniform. That rust is from the plain steel 36 year old bracket that the lifting ring attaches to the transom with. Those bolts are not under water at rest.
I do appreciate you pointing that out as i don't like unscheduled swims.:eek:
POWERPLAY J 12-17-2011 07:01 PM
Looks great! You can launch at the DNR launch by Selfridge. No docks but you can tie it off on the wall.
CIG3 12-18-2011 10:24 AM
Boat looks great after all these years. I help Tim re-rig after he purchased from Northernoffshore. I fabbed up the port gauge pod and did all the wiring. The boat had crank driven water pumps which I whiched over to the cam driven style. She is a great boat with many stories. Good luck.
h2oboater 12-18-2011 10:54 AM
I saw you Friday taking the pictures at West Marine on South River Rd. Good to see this Cig has a new home on Lake St Clair. :drink:
THEJOKER 12-18-2011 05:19 PM
Nice boat and I saved all the pictures. I have a 1973 28 SS that is is good shape but needs a resto.
