-   -   top gun battery charger. (https://www.offshoreonly.com/forums/cigarette/254001-top-gun-battery-charger.html)
STRAIGHTPRIORITY 05-20-2011 09:18 AM
My charger just stopped working. is there any type of breaker or anything?
Or is the charger shot?
couldn't really find info on this.
cigrocket 05-20-2011 09:26 AM
1 Attachment(s)
Mine has a breaker on the on/off switch directly on the unit. It needs to be pushed in. Also, did you accidentaly knock the cabin switch? That's just the 2 that I know of, good luck.
This is a picture of mine, it was painted red. The switch is in the upper left corner next to the meter.
STRAIGHTPRIORITY 05-20-2011 09:30 AM
i did check the cabin switch and couldn't find one on the unit.
my luck its probably bad.
TexomaPowerboater 05-20-2011 09:50 AM
Dayum, there is really not much room in the engine bay on those 38's...........
CigDaze 05-20-2011 10:15 AM
If I'm not mistaken I think he has TRS drives, so the trannies push everything forward. There's actually a ton of room in those compartments. I can actually get myself in between my engines and the bulkhead, and I'm not a small guy.
CigDaze 05-20-2011 10:17 AM
Mine went bad too a few years back. I replaced it with a Zantrex unit and I couldn't be happier. It's a great charger! It has remote monitoring and programming, too.
http://www.google.com/products/catal...=1453&bih=856#
BDiggity 05-20-2011 10:53 AM
+1 i replaced the old charger w/ a xantrex charger/converter.
STRAIGHTPRIORITY 05-20-2011 11:09 AM
yeah i can sit infront of my motors.
that seems pretty reasonable.... always somethin i guess
CigDaze 05-20-2011 11:11 AM
Yes it is. I know all about that. :D
cigrocket 05-20-2011 12:24 PM
It is a SSMIIIA boat, but you are correct. Trannies make it tighter. But Speedmasters give it reliability and the possibility of adding more HP...:drink:
