fuel sending unit >
fuel sending unit
fuel sending unit
Old 05-31-2011 | 01:06 PM
Default fuel sending unit
Does anybody have a part number or manufacture for a fuel sending unit for 1993 top gun fuel tank or a good place to start looking.
riski bidness is offline
Old 06-02-2011 | 07:35 PM
I just put a Wema sender in my Mistress. I don't think you'd have much luck with the same make/model of sender, you're talking nearly 20 years. Most have the same ohm(resistance range). It was an easy replacement. Disconnect all the batteries, remove the sender, measure to the bottom of the tank, buy a sender thats about 1" shorter, and re-install. Remember you're dealing with a tankful of gas, so use all due precautions.
I measured 16.5" to the bottom, but bought a 14" sender for two reasons. First, it was all the store had at the time, and second, the V is very sharp in the bottom of my tank, so if the sender goes all the way to the bottom, as the tank gets low and the lever starts being in the V, it's measuring a smaller amount of fuel for a given level. Maybe I just am rationalizing my impatience.
Good luck.
bustedbrick is offline
Old 06-08-2011 | 06:17 AM
Zero Patience's Avatar
Livorsi, about 55$ each.
Zero Patience is offline
Old 06-08-2011 | 02:47 PM
I put a couple of these in the Bullet a few years ago.
http://www.hardin-marine.com/Instruc...vel_Sender.pdf
Screamineagle is offline
Old 06-08-2011 | 08:48 PM
jbraun2828's Avatar
What size sendors (how long), did you get for your bullet? I need to replace mine as well. Thanks Jason
jbraun2828 is offline
Old 06-09-2011 | 08:25 AM
Default Jbraun2828
Try a company out of edgewater Fl called Centroid Products. They used to supply cigarette with there sending units. The lady I talked to has been there over twenty years . I just got two sendings units for my top gun part # CGF-24 They will cut the tube to lenght and is already calibrated.Tel # 386-423-3574 or Rex Marine has them but you have to cut the tube
Old 06-09-2011 | 09:03 AM
jbraun2828's Avatar
Thank-you
Old 06-14-2011 | 07:15 PM
Looks like I ordered the 12 inch version. It's not perfect but I think it's much better than a float sender. Only problem I had was getting the old ones out, those little screws seemed like they were welded in there!
Old 06-14-2011 | 08:16 PM
got mine from them also .make sure to tell them you want delay added .it will stop the gauge from bouncing all over the place .i gave her the # on my send units and it had dly on it and she said it ment delay added
smokin' gun is offline
