A little help guys? >
A little help guys?
A little help guys?
Old 05-20-2012 | 06:33 PM
Default A little help guys?
Anybody know a part number for this pump? It's the fresh water pump out of my 1995 Top Gun. I took it out today and there are no part numbers or even a manufacturer name or anything...just a caution sticker
Thanks!
jasonmd2 is offline
Old 05-20-2012 | 06:34 PM
Ahh, forgot the picture
jasonmd2 is offline
Old 05-20-2012 | 08:09 PM
Zero Patience's Avatar
A diaphram pump. I will give you the number tomorrow. I purchased 4 of them this month.
Zero Patience is offline
Old 05-20-2012 | 08:39 PM
thisistank's Avatar
How is it I owned that boat for 6 years and I've need seen tht before in my life!? LOL.
thisistank is offline
Old 05-21-2012 | 05:14 AM
Thanks Jim!
That's probably why it doesn't work oh and because it's behind the amps in the storage locker in the cabin
jasonmd2 is offline
Old 05-21-2012 | 10:31 AM
What is this pump hooked to or used for?
Harvey is offline
Old 05-21-2012 | 11:02 AM
cigrocket's Avatar
freshwater holding tank pump
cigrocket is offline
Old 05-21-2012 | 11:46 AM
The one in the picture is like a Jabsco #36960-2000, or west marine# 109951. These have no pressure switch. Most fresh water pumps have a switch. Like a shur flo # 4901-4292. The diaphram pump is what is in the bilge on mine. Firewall mounted with the pickup right at the tramsom drain holes to empty the bilge of all water.
Old 05-21-2012 | 07:57 PM
Thanks Jim!
To save a few bucks could I use Shurflo 3901-2214? Looks like only difference is 3.5 GPM vs. 4 GPM
jasonmd2 is offline
Old 05-21-2012 | 08:55 PM
Sure, you might have to create a suction on the discharge line the first time to prime it. Then it will work fine
