How to put a Notch in a Flat Deck >
Old 02-14-2013 | 06:03 PM
cougarman's Avatar
Look foward to the pics, Great Project
Jon
cougarman is offline
Old 02-14-2013 | 06:37 PM
Orion I just had a thought and a chuckle. If you think my project is daring you should read the post about the guy who cut his 35 Cigarette down and made a 28 open out of it .
RG.
Rick G is offline
Old 02-14-2013 | 07:46 PM
Originally Posted by Orionsilverboat
Your going to be very suprised how hard it is, cutting the hull like that is a big mistake, it will never be the same structurally, good luck
BULLSH*T if you knew a tenth of what Rick G knows about glass and composites you'd be a GURU...
comment not please, only positive reinforcement needed here!!!
adk61 is offline
Old 02-14-2013 | 07:51 PM
Originally Posted by Rick G
Orion I surely hope you are wrong about the structural integrety. Phil at Lipship marine certainly didn't share your concern as he has done this modification on more than one occassion . Given the bonding materials today I am hoping that the structure will the same if not better . Hulls are repaired successfully on routine basis these days I hope mine falls into that category . Besides there is no turning back I already cut the hole.
RG.
don't lose a seconds sleep over it buddy... do you think I would have handed you the sawsall if I didn't think you were up to the task? lmao!!!
and then the Scarab is next to go under the blade!!! BOUAAAAHHHHHAHAHAHAHAHHA!!!!
adk61 is offline
Old 02-14-2013 | 08:14 PM
Wouldn't surprise me if some crazzy guys on here build some steps in a flatbottom...LOL... but why not ?
cafe man is offline
Old 02-14-2013 | 08:29 PM
Cafe Man don't give me any crazy ideas . Come to think of it I think I saw a 41 Apache for sale that had a step put in it. I never heard whether it actually worked . All kidding aside given the type of boating I do ( pleasure) I have never been a fan of step hull boats not withstanding the performance advantages . Even thought straight bottom hulls are slower I think they are just more predictably ( read easier ) to drive . Just my personal opinion.
I will post pictures of my adventure as it progresses .
RG.
Rick G is offline
Old 02-14-2013 | 08:32 PM
That Apache you're referring to looks like a mess on the bottom. I've seen it in person. Good luck with your project.
redbud35 is offline
Old 02-15-2013 | 08:45 AM
Cored Hull or Solid? Make sure you grind back real good all around seam before starting layup, at least 8 or 10 inches.
automobili_v12 is offline
Old 02-15-2013 | 08:57 AM
Rick, I am the guy that is redoing the 35' Cig into a 28' cc. You have no reason to be concerned with structural integrity as long as you use the right materials and proper prep. These hulls are laid up with polyester and last for decades, so by using superior vinylester and epoxy resins with new fabrics you can improve the structural integrity. Do make sure to taper the bottom laminate back from the cut to maximize the bonding area. I applaud your project. Just got the teak floors installed in the 28. Hope it does not fall apart !
ren3 is offline
Old 02-15-2013 | 09:14 AM
Automobili , it is a solid kelvar hull no coring ( thank god one less issue to work around). To clarify the hull is laid up in alternating layers of Kevlar weave and mat . The basicc hull I counted to be a total of 18 to 20 layers . the stringers areas and especially the keel are significantly thicker( more than double in the keel area) . I agree I had intended to fearther out at least 6 to 8 inchs on the outer hull and 8 to 10 inches on the inner hull in addition to tying the the center and next stringers throught the notch into the new transom I am doing . I am certain it will be plenty strong. The lay up will consist alternateing layers of biax and trix with kevlar for good measure , bonded with a particular vinylester resin.The finished uncored notch should be atleast 3/4 of inch thick at the thinest part. I'm goung for strenght not weight ( keep in mind it is only a 9 x 9 inch notch).
Rick G.
Rick G is offline
