Fuel tank question for cig owners
2003 cigarette w 525s . Is it poss to run both motors off 1 tank . My cig has
A bunch of ball valves mounted on top of the tanks however u really can't see where
All the lines go . Can it really be done and does anyone have a diagram of it
??? I know my old top gun could but it had valves at the fuel filters this is not setup
That way. All valves are mounted on top of fuel tanks and also only 1 feed line to fuel pump
Sorry for the delay getting the info back. I looked at the setup on my 03 TG and there are two valves on each tank. One goes straight to the engine and will be open, and the other feeds the opposite side (crossover) and will be closed. Basically all you need to do to run from a single tank is make sure both valves on empty tank are closed and both valves on the remaining tank are open.
There is also a tag on each side that reads as follows:
Fuel Tank Crossover Valve To Operate:
1. Open crossover valve (handle Parallel to line)
2. Close Valve From Empty Fuel Tank (Handle perpendicular to line)
3. Do Not run wide open throttle while crossover is open (Minimum fuel pressure 4PSIG)
