-   -   Cafe AC installation pics? (https://www.offshoreonly.com/forums/cigarette/319894-cafe-ac-installation-pics.html)
anewway 11-06-2014 10:04 AM
Hi!
I've been toying with installing AC on the Cafe. I know there are some out there with it already installed, does anyone have any pictures of the system?
Has anyone done the install themselves? If so, any hints? What brand/size did you use?
Thanks!
Full Force 11-06-2014 11:43 AM
I used a 7000 Cruisair in the Mistress, not hard to install, the cafe has more places to hide stuff then mine, buy a good water pump and T off sea strainer then you dont have to drill hull for another hole...
dont waste money on install kit, most parts can be bought at Home Depot.
Flamingo 42 11-06-2014 08:32 PM
2 Attachment(s)
I put air/heat in the tiger last winter definitely made staying on it more comfortable, bought the Webasto but be careful on the sizing because their units are rated differently ...their 6000 is the same as others 9000, call the tech line for help. Here are some pictures of mine after install.
Flamingo 42 11-06-2014 08:35 PM
sorry, couldn't rotate bottom picture of the unit in the closet
jeff32 11-06-2014 08:38 PM
And how much did you spend to buy and install it?
Flamingo 42 11-06-2014 08:47 PM
I think I had $1400-$1500 into the whole thing, I bought a used sea strainer from the swap shop and shopped for all the other parts. I bought matching liner for the closet and mounted the unit high so I could still use the closet and access the water pump, it also made it easier to duct and run water lines.
anewway 11-07-2014 12:33 PM
Thanks! I don't have that closet on the Cafe.
I did a search here for some Cafe install pics,and there are a few threads, but the pics are gone. I'm guessing those were linked pictures.
Skramer is looking to see if he still has pics of his install.
Flamingo 42 11-07-2014 07:54 PM
I called down and talked to Phil at Lip-Ship, he was so willing to offer advice and send pictures of installs, a true class act
SKRAMER 11-08-2014 07:32 AM
I found the thread I posted them on but the pictures are gone. I'll have to take new pictures.
http://www.offshoreonly.com/forums/c...94-cafe-c.html
anewway 11-11-2014 04:01 PM
Yeah, I had found the thread as well, but as you said,the pics are gone. Bummer, I was hopping you wouldn't have to take new ones.
Thanks Flamingo, good idea, I will ping Phil too.
SKRAMER 11-12-2014 08:12 AM
5 Attachment(s)
Hope these help. The vent in front needs to be bigger.
anewway 11-12-2014 09:28 AM
Cool, thanks!
I had forgotten how different your interior is compared to mine. But, that gives me some ideas.
Did you tie into the inlet and outlet for the head for the water?
Does that size unit cool things down enough?
I will only be using it at night while at the slip, but some of the nights here are pretty damn toasty.
SKRAMER 11-12-2014 09:56 AM
Unit works Awesome, Yes tied into the inlet for the head. Put a separate water dump for the AC.
jeff32 12-13-2014 08:12 AM
A marine unit of course! That is what you are talking about right?
Cause i dont think my local professionnal a/c guy would be the best for my boat!
mmb 12-13-2014 09:40 AM
Originally Posted by Jeff Elinger (Post 4234191)
Air conditioning unit is of different types some are small and some are big, some are split and window but these can pe perfect installed by only the professionals. So hire a Professional and well experienced Air Conditioner Installation*Company so that the AC unit should be properly fixed with great care.
Great when the A/C breaks down in my house i will call them... Any helpful info for an A/C unit on a boat?
