Length of travel for hatch "roller" >
Old 02-17-2015 | 11:19 AM
cougarman's Avatar
Originally Posted by frickstyle
Trying to design a simple mount for the Lift Arm under the Hatch. Can anyone measure what the length of travel is on a center mount factory roller setup? I need to determine how long to make the mount and I do not have anything available at the moment to measure. Easiest would be to measure the witness marks on the channel under the hatch where the wheel goes back and forth.
Need minimum dimension in picture below, hatch closed / hatch extended. .
[ATTACH=CONFIG]537004[/ATTACH]
Its really depends on the pivot arm, you can create as much or as little travel as you would
like based on the pivot point location of your pivot arm.
if your doing custom Fab, or custom cnc billet... You might be better suited
to mock a few concepts up with wood and figure all your pivot points
then take it to the next level.
Jon
cougarman is offline
Old 02-17-2015 | 11:21 AM
cougarman's Avatar
I have to make this bracket and swivel mount that attaches to the tip of the arm. Will post pics when complete. Hoff came up with roughly a 9" slot length (thanks), any thing different before I start to make chips?
[ATTACH=CONFIG]537059[/ATTACH]
If you have CAD software you can automate the motion and build to suit very easy.
What software are you using.
Jon
Old 02-18-2015 | 07:46 AM
i still have the old slide and the travel is 6 and 1/4" (actual slot length 6 and 5/8th) and both side of the hatch where they will mount are flat and linear from front to back and about thre inches wide so they and bolt anywhere (pretty much exactly like the 39's) Also the original slot length worked for the flat hatch as well as the 575 hatch so nine inches should be plenty of throw. If you use the same basic dimension (arm length and such) of the one mounted in the center all should work good
Yes, this will be "plug and play" using stock arm length and mounting to the cylinder. It's actually staying on center. Dave, can you take a pic of the underside of the hatch? I may have to fab up some spacers to make up height. Also, second engine is now at boat, would you be free in a week or two to head out there? Still rigging and such for the next couple weeks, or we can install @ XT?
frickstyle is offline
Old 02-18-2015 | 12:13 PM
glassdave's Avatar
Neno the mind boggler
I'll see if i can flip it over an get a pic but the area where the lift arm will mount is unchanged, it is essentially a stock 575 Cig hatch. You probably wont need much of a spacer either maybe couple inches at the most possible a riser block, the stock arm has enough throw to compensate for the different height. On all the boats that I've put them on i didn't notice any difference in opened height, if memory serves the factory ram puts the hatch nearly straight up if you limit it out so there was plenty of lee-way.
I can come out in a couple weeks, XT works to if need be Dave is doing some stuff for me at the moment as well and i have to.go down to select some colors. Great to hear both motors and the boat are finally all in the same building, i think this could be your year
08 OPA High Points Champion
glassdave is offline
Old 02-18-2015 | 01:10 PM
a, yeah let's hope so. It's been a long time coming. I'll get a hold of you when I have more concrete plans. It would be good to fit it at rigger's shop so Dave has no hold ups as I'm sure he'll be busy enough at the moment. Thanks for the hatch info, I'm sure it will be fine, will leave the throw at 10" (minus the length o the swivel block which is 3", should be fine).
Oh yeah, new manifolds and plumbing complete, time to drop it in???
[ATTACH=CONFIG]537269[/ATTACH]
Attached Thumbnails Length of travel for hatch "roller"-img_20150218_112431_681.jpg
Old 02-18-2015 | 06:01 PM
glassdave's Avatar
Nice! Eikert Exhaust. I had a boat with those once they are fantastic but in a single it had an odd problem (i thought anyway) I thought they sounded like an old pickup with the muffler off (from the cockpit), had someone take it out and buz by while i waited on shore and they sounded flippin awesome (really awesome). For some reason they just sounded odd (in that boat) from the cockpit
hey, you can hardly see the cool artwork on the valve covers lol
Old 02-19-2015 | 07:14 AM
I would love to have tubular stainless exhaust (true headers), but I like the reliability of these, plus I needed the clearance. I think it may be the equal length tubes that makes them sound good (maybe odd from inside). See ya soon.
Old 06-25-2015 | 01:44 PM
OK, got the assembly machined and dropping it in the mail off to XT. Coming up to the finish line, this is where everything "falls into place", right?
[ATTACH=CONFIG]542475[/ATTACH]
All Aluminum with 316ss rod, fasteners and snap rings, etc. Stuff adds up quick. Mount machines from 3" x 3" x 16.5" Al and slider block was something I had in the shop (Al). Turned the Nylon slider bushing and added a snap ring groove, looks pretty clean without cotter pins or thru bolts, etc.
I made a drawing if anyone is interested in making their own. They cost too much to re-sell, way too much....
I will post a pic once all is installed, and one with me on the water!!!
Attached Thumbnails Length of travel for hatch "roller"-img_20150625_135102_392.jpg
Old 06-26-2015 | 05:19 AM
Zero Patience's Avatar
I would like to make one, that's a choice piece. Please send drawing. I will pm address.
Zero Patience is offline
Old 06-26-2015 | 07:31 AM
Zero, I will send it. Another member machined the lift arm to look like the new ones also, kinda pricey, I do not have a pic of that.
Also, I changed a couple minor things, I will update the drawing and send it. Also, let me make sure this works, I'm a little nervous on the "twist" it may experience because this is a single lift point, where as the new ones have one each side. Does your staggered setup use two arms???
One more thing, I set the "throw" for about 7.5", you may require more depending on how long your arms are and where they pivot. Easy adjustment to make, just lengthen the base and rod.
