1984 38 Flat Deck Fuel Tanks Question >
Old 10-06-2015 | 08:48 PM
Default 1984 38 Flat Deck Fuel Tanks Question
I just purchased a 38 Flat Deck and am told that it has two 100 gallon tanks in it and that they were somehow connected via a transfer pump. What I am wanting to know is if there is a way to connect both tanks so they both fill evenly from one side or the other and if you can connect them via a manifold to use both tanks for both engines. I tried searching the forums but could not find the answer. Any help would be great.
Scarab9626 is offline
Old 10-06-2015 | 09:02 PM
Full Force's Avatar
You can make them however you want with some effort, ICDEDPPL Dan will chime in I am sure on this....
Full Force is offline
Old 10-06-2015 | 09:11 PM
MrCIG's Avatar
Charter Member#330
I believe the 84's have the same tanks as the 85 and 86's they should be 130 Gals each if they are original
Mark
MrCIG is offline
Old 10-06-2015 | 10:53 PM
Why not just run one engine off each tank and be done with it????
Griff is offline
Old 10-06-2015 | 11:06 PM
Mine were 140 gallon tanks. Not sure why or what you`re trying to accomplish thou.
ICDEDPPL is offline
Old 10-07-2015 | 05:29 AM
cigrocket's Avatar
Keep them separate, like they came from the factory. Especially if you run into fuel or engine trouble. 2 tanks are the way to go with an offshore boat.
cigrocket is offline
Old 10-07-2015 | 06:32 AM
Wow very interesting . I always thought that the total fuel capacity of the 38 footers was 150 gallons total .
My tanks have never really been empty and don't remember ever putting that much fuel in . I guess you learn some thing new every day .
RG.
Rick G is offline
Old 10-07-2015 | 08:34 AM
seafordguy's Avatar
I would want them separate. I like having 2 completely different entities in my boat.
Just fill them both to the top - then you know they are even.
seafordguy is offline
Old 10-07-2015 | 09:36 AM
MrCIG's Avatar
Charter Member#330
Here is the original brochure for the 38's
Mark
MrCIG is offline
Old 10-07-2015 | 08:22 PM
Thanks for all the help. What I was wanting to do is make sure they both empty evenly and also be able to fill them both from one side of the boat or the other. I can fab a manifold to make them both drain to both engines and also be able to separate them if needed. I was just trying to come up with a good way to fill them both from either side of the boat.
