Bolster base fasteners into floor >
Old 07-25-2016 | 07:10 AM
Default Bolster base fasteners into floor
I have a few loose screws in my bolster base. Went to put a lock nut underneath the floor only to find out that the fasteners are glassed in under the flooring. Does anyone have an easy solution here? Is it a plate that is tapped, can I try a longer fastener to "catch" the threads (maybe the plate lost adhesion to the under side and the screw can't catch it?). Any help, much appreciated.
frickstyle is offline
Old 07-25-2016 | 07:21 AM
CIG3's Avatar
Should be a piece of 1/4-3/8 flat aluminum plate tabbed into the floor. They usually strip out when the bolts get loose. Can you feel a nut on the bottom?
CIG3 is offline
Old 07-25-2016 | 08:17 AM
Sydwayz's Avatar
Forum Regulator
Perhaps a solution for you here:
http://www.offshoreonly.com/forums/f...s-how-fix.html
http://www.offshoreonly.com/forums/f...rew-holes.html
Sydwayz is offline
Old 07-25-2016 | 12:14 PM
Seems like plates tabbed in, cannot get to plate or to put a nut on. thanks for the links, makes a lot of sense now. I will see which method will work best based on clearance and what's going on with the stripped plate.
Old 07-25-2016 | 01:33 PM
Team Archer's Avatar
WE have drilled a bigger hole in the base and then retapped the hole in the floor for a larger bolt.
Team Archer is offline
Old 07-25-2016 | 02:28 PM
That sounds like a viable option also, thanks.
