Cabin Project.........What did I do. >
Old 02-10-2017 | 03:55 PM
  #51
Ironmanwb's Avatar
Originally Posted by SKRAMER
Probably not going to make early birds but we are pushing to get it done. It may not be 100% complete this year either because we have future plans for the boat and don't want to back track.
Ironmanwb is offline
Old 02-10-2017 | 07:43 PM
  #52
Ironmanwb will you be laminating all that wood you are laying down, cabin and floor. ie ( covering in fiberglass on both sides/ top and bottom)? I strongly suggest that you laminate the bottom side first and then laminate top and in tab in place. Or at the very least brush some resin over it to protect the exposed wood. Good progress so far and love the boat.
PG-13 is offline
Old 02-11-2017 | 04:35 AM
  #53
Ironmanwb's Avatar
The cockpit floor will be the cabin floor is but the rest I'm not sure of. A lot of the stuff we pulled out of the cabin was original and had zero rot after 45 years so I don't really see the need. We are trying to keep the weight down as much as possible. Eliminating lots of unnecessary stuff old rigging and cobbled glass work.
We will make sure everything that will see a lot of moisture will be coated.
Old 02-11-2017 | 06:23 AM
  #54
Full Force's Avatar
Jr, he did Snyders complete restoration, that will tell you how good he is....
Looks sweet ironman!!
Originally Posted by J-Bonz
I have heard his name referenced a few times but it seams his good work flies under the radar. I really liked what he did with the squadron. Really excited to see how this turns out for you!
Full Force is offline
Old 02-11-2017 | 06:28 AM
  #55
Full Force's Avatar
You and I know Bruce will do what he thinks is needed or mandatory, gonna be sweet dude...
Old 02-11-2017 | 10:01 AM
  #56
Ironmanwb's Avatar
I told him to build it the way he build his own.
Trying to keep it simple and make sure when we start the next phase we don't have to go back and redo it.
Old 02-11-2017 | 10:08 AM
  #57
If you were thinking of using epoxy to seal/clear coat wood exposed to the sun, must epoxies arent totally uv stable, meaning they will yellow over time if in direct sunlight. West systems has some stuff that is more uv friendly but I have even seen that discolor after while.
phragle is offline
Old 02-13-2017 | 04:31 PM
  #58
Ironmanwb's Avatar
Anything that is exposed will be covered or gel coated. Still not sure what we are going to do for the cabin sole or cockpit floor. I want mahogany or bloodwood but I know that it is a lot more to care for.
Old 02-14-2017 | 09:01 PM
  #59
Ironmanwb's Avatar
Cockpit floor roughed in, 1/2 of the rigging moved over . Bulkhead cutout for new cabin door, cabin interior structure getting built. Batteries getting a new home.
[IMG][/IMG][IMG][/IMG]
[IMG][/IMG]
Old 02-14-2017 | 09:03 PM
  #60
Ironmanwb's Avatar
[IMG][/IMG]
