Gladiator info >
Gladiator info
Gladiator info
Old 03-28-2017 | 06:54 AM
Default Gladiator info
Hello Guys,
I ran some searches but didn't get anything consistent. I'm looking for some guide lines on the Glad. I know that some of the cockpits have a slightly wider configuration than some others. Is this based on anything? Did they start this during a partuclar yr? or was it done as an option? Did it have any relation to the side by side or stagger set up?
Thanks,
Tom
tomcei is offline
Old 03-28-2017 | 09:22 AM
The first yrs of the Gladiators had the tight "shoulder rubbing" cockpits. It has nothing to do with being staggered or side by side. Of course the staggered configuration does have a smaller cockpit in length but not in width. The Gladiators for me is the nicest Cig out there. It's a fun hotrod.
SkaterMike82 is offline
Old 03-28-2017 | 09:30 AM
J-Bonz's Avatar
Tank or LS Jr. Will know
J-Bonz is offline
Old 03-28-2017 | 03:44 PM
thisistank's Avatar
First few built were the narrow cockpits. You can tell when you see them because there's almost a walkway on both sides next to the cockpit. I think it was due to being a purpose built race boat. Then when they went more recreational they opened them up.
thisistank is offline
Old 03-28-2017 | 06:15 PM
It was done if the customer wanted. You can get either in a side by side or staggered configuration. The easiest way to tell which it has is look at the edges of the dash. If it goes straight down its a wide cockpit boat, if it has kind of a curved edge it's a narrow cockpit boat
Lucky Strike Jr is offline
Old 03-28-2017 | 07:34 PM
thanks guys! what was the last yr they built them? I recall the Virgin boat was first correct?
tomcei is offline
Old 03-28-2017 | 11:49 PM
thisistank's Avatar
2008 LipShip "Last Gladiator" was the final Glad. 700/NXT's. Virgin was the first. Built to race in F2 and replace Tres Martins F2 TS Gun. I think the new owners of the virgin Glad should name it "First Gladiator"
Old 03-29-2017 | 12:03 AM
Sydwayz's Avatar
Forum Regulator
How about just "OG" ?
Sydwayz is offline
Old 03-29-2017 | 12:10 AM
Great boats good luck on your search you will love owning one!
offshorexcursion is offline
Old 03-29-2017 | 10:45 AM
thisistank's Avatar
OG with ghost script behind it only visible in certain light "ORIGINAL GLADIATOR". That would be bad azz plus a play on OG.
