fuel tank question >
fuel tank question
fuel tank question
Old 04-19-2021 | 10:24 AM
Default fuel tank question
Guys,
First post as a cig owner.. Excited as hell.. How do you switch for one fuel tank to the other? I didn't see a switch. I didn't look that hard either. I assume they are independent of each other and you have to fill separately and switch them?
Thanks Guys... Matt
bossmjb is offline
Old 04-19-2021 | 10:54 AM
H20 Toie's Avatar
Would help to know what year and model you have since there were differences
H20 Toie is offline
Old 04-19-2021 | 01:05 PM
lol, i guess that would help... sorry...
03 38 top gun...
bossmjb is offline
Old 04-19-2021 | 01:25 PM
Drake22.250's Avatar
Congratulations on your Cigarette! You have to fill each side of boat​​​​​. It should have one tank fuel each engine. On the front step in front of engines is a door(center) with valves that will shut Fuel tanks off. Both should be open. Enjoy your new ride. Post some pictures after you have 10 post on OSO.
Drake22.250 is offline
Old 04-19-2021 | 01:47 PM
BDiggity's Avatar
Originally Posted by bossmjb
Guys,
Thanks Guys... Matt
mine are independent of each other. no way to draw between the two.
BDiggity is offline
Old 04-19-2021 | 01:56 PM
H20 Toie's Avatar
What drake said plus if needed you can switch the valves so that both motors run off of one tank.
FYI most boats you will find that one motor uses more fuel than the other. on my 35 i found that i would use about 10 gallons more in one tank.
also don't believe the gauges , when you get to half a tank you are acually closer to 1/4 of a tank. when you hit a 1/4 you better be close to a marina.
I assume on a 03 you have 500efi's or 525s so you should be able to run close to 200 miles when running 70-75
H20 Toie is offline
Old 04-19-2021 | 03:16 PM
It has 575 sci w/intercoolers.
bossmjb is offline
Old 04-19-2021 | 04:39 PM
So I`m not the only one!! ??
Sweet.
I wonder why that is
ICDEDPPL is offline
Old 04-19-2021 | 04:55 PM
Guys,
Thanks Guys... Matt
Shoot me your number (630 774 493 seven)
Mark wanted to tell you how those switches work.
ICDEDPPL is offline
Old 04-19-2021 | 06:39 PM
Originally Posted by icdedppl
shoot me your number (630 774 493 seven)
mark wanted to tell you how those switches work.
7159237768
bossmjb is offline
