Cigarette adventure (new transoM and #6 conversion) >
Old 08-10-2022 | 07:20 PM
Mounted tabs vertically but they only went as high as level with hull.
ICDEDPPL is offline
Old 08-10-2022 | 07:22 PM
So after some facebook discussions where half said fine, others said no bueno I gave em a little more lift.
Can`t hurt.
ICDEDPPL is offline
Old 08-11-2022 | 10:55 AM
BBYSTWY's Avatar
Good lord here we go again hahaha. Looking amazing as always Dan! Probably missed the thread as I haven't been on here in awhile, but what happened with the motors? Saw you were selling your heads and obviously they are out for the drive change but are you going bigger with those too??
BBYSTWY is offline
Old 08-11-2022 | 12:44 PM
thisistank's Avatar
Those tabs look bad azz!!
thisistank is offline
Old 08-11-2022 | 03:30 PM
Tank, PM me. Thanks
1Zoom is offline
Old 08-11-2022 | 04:25 PM
Can`t hurt.
been going through the same, but thankfully they came with multiple holes.
I ended up with them level, I like how responsive they are and the ability to stuff the bow. However I’m not sure if they are touching when running wot, on the one hand my boat should be standing up on the pad. But if it has some angle to it, I could see how they might be touching the water.
I also like level because it gives me some effective tab down when planing off with out having to do anything.
hogie roll is offline
Old 08-12-2022 | 08:22 AM
Wally's Avatar
Were doomed!
I'd be curious why they thought it was not good...i see nothing wrong with it. The tabs are under the greatest stress when they are forced down into the water. The cylinder is trying to get pushed pack into itself at that point. All the stress is on the side of the bolt that trying to push it back in. You have tons of meat on that backbone you drilled....id be more worried if the old hole was on the other side of how its mounted right now as it would weaken the surrounding area when its getting pushed on.
-Wally
Wally is offline
Old 08-12-2022 | 10:03 AM
Thumbs up
Izoom Mike did a fantastic jobs on them !!
Old vs. new
ICDEDPPL is offline
Old 08-12-2022 | 10:11 AM
Some responses:
I played with my tabs & trim for over an hour one day, with trim angles & tab angles. Never once did having the tabs level, ever scrub speed. There’s no reason to have them higher than neutral/level with the bottom. Just an extension of the hull at that point.
I never ran my tabs above neutral so I’d think you’d be fine as it sits. I can’t really think of a reason to be above flat unless you’re looking for the last .5 mph and that’s such a small window of operation.
n
For cruising its probably fine but all out speed it wont release the suction and will cause some drag.
]Scott Rutherford
To all that say flat is fine!!
NO ITS NOT
well, I ran a few boats in my life (I think), and even if water isn’t there… air is
It won’t work.
If it works for you then maybe your boat just isn’t fast enough? Not trying to sound negative, I don’t know your boat.
But a 38 cig that runs over 75-80 mph should not have tabs level in a turn or when it’s not more the. 2-3 foot seas!
I rig and set up and modify all kinds of boats and test them and dial them in.
Again, I don’t know your boat, but just because the apple tree grows in your yard, don’t mean it would grow in his!
Anyway it was no big deal to go higher.. and now they are adjustable. Big heavy Cig with 1000# engines and 1200# of drives that transom will be heavy .
ICDEDPPL is offline
Old 08-12-2022 | 11:59 AM
Wally's Avatar
Were doomed!
got it....Well just me thinking out loud here...i can see keeping them dead level as an extension of the hull....(assuming the tabs stop exactly dead level each time and ive never seen a pair do that yet) Otherwise it would be an interesting experiment to see at what speeds the tabs stop contacting the water if they are kept level....(assuming yours are mounted 3/4"-1" above the bottom of the boat) My guess is they would always contact at least on the last parts of the tips no matter how fast you can go. So if that's the case it would affect the nose up/down adjustability of the boat somewhat. Raising them higher allows you to possibly be able to raise the nose of the boat higher not having the drag of the tab trying to force it down....i see it as a win either way
-Wally
Wally is offline
