Bullet Fuse Panel Wiring >
Old 08-20-2024 | 08:44 AM
Default Bullet Fuse Panel Wiring
Under the helm there is a small opening that has a fuse panel with 5 or 6 glass fuses. It appears to be factory, but mine looks as though wires have been moved/removed and added.
I want to replace the fuse panel with ATC fuses and would like to identify and label each circuit. Does anyone have the factory layout as to what these feed? It would be a huge time saver since I don't have the dash in or the batteries connected. I could confirm with an ohm meter, then figure out the added circuits.
Shah Mat is offline
Old 08-20-2024 | 10:00 AM
Wally's Avatar
Were doomed!
See if this works/helps any...
File Type: pdf
-Wally
Wally is offline
Old 08-20-2024 | 06:22 PM
Wally,
Thanks that is helpful. The binder I got from the previous owner has pages 3&4, plus some others. Obviously I'm missing pages 1&2.
The diagram shows toilet, stereo, mercathode/halon. There are a few more, but that is a start.
Shah Mat is offline
