Post your Oldschool ride! >
Old 10-05-2022 | 12:58 PM
  #2191
F-2 Speedy's Avatar
am I seeing an alternator direct connected to the crank shaft ? never seen that post 2182
F-2 Speedy is offline
Old 10-05-2022 | 01:15 PM
  #2192
Good question.
I wondered what front drive setup that was?
Guess seawater pumps cam driven.
Also hydraulic cylinders on transom, but I see no steering pumps??
Why the need for 2 tie bars also?
cheech is offline
Old 10-05-2022 | 01:54 PM
  #2193
The boat will have an old school hydraulic pump in the helm... All manual input with no assist (obviously)... Think of early o/b skaters
The 2nd tiebar on the steering is likely (only guessing here) to keep the push/pull effect of the steering rams equal on each drive
speicher lane is offline
Old 10-05-2022 | 02:13 PM
  #2194
That's what I thought at first.
An outboard hydraulic setup.
Never knew they used them on sterndrive boats.
cheech is offline
Old 10-07-2022 | 04:27 PM
  #2195
From: Palm Beach County, Fl. ( formally N. California)
Default Arena Craft... The first boat I drove
Actually Howard Arneson's first boat using the prototype Surface drive. I think this is the only photo of the boat. Powered with a Crusader Marine 350 Chevy.
mountie is offline
Old 10-08-2022 | 06:55 AM
  #2196
I have never seen this type set up? I was told the engine stuff is jet boat type stuff? No belts anywhere, water pump off cam, alternator off crank. The steering I have no idea except I don’t like it lol. I am changing that this winter. Going to redo the transom, stringers and modernize the interior and stereo. I will leave the motor setup, it really works well and is something different!
ScottyChatham is offline
Old 10-10-2022 | 11:18 AM
  #2197
Well as speicher lane said, the steering has no power assist. My guess is that's your issue with it?
So you'll have to add a hydraulic helm, lines to it, pump, and reservoir.
The pump situation might get difficult if there isn't any access to get a belt to your steering pump with your existing front drive setup.
Guess there isn't even a lower pulley?
cheech is offline
Old 10-10-2022 | 11:41 AM
  #2198
No lower. I have been talking to a couple of companies about electric pump, similar to drive and tab pumps to use as power steering. I think I will change helm and give it a try.I seem to like to do things different
Old 10-11-2022 | 11:52 AM
  #2199
Team Archer's Avatar
IMCO makes an electric power steering system that we use on outboards. Works great Give them a call they will set you up.
Team Archer is offline
Old 10-12-2022 | 04:36 AM
  #2200
Quinlan's Avatar
OK so Not OffShore
But I picked up this Tub for next to nothing and will be starting a rehab this winter. Prob 16-18'. Some sort of Chevy V8 and Jet drive.
I have seen a bad pic of one that was in a Bond movie and trying to figure out which movie so I can some get paint ideas.
Probably early 60s. and the name on it is JEW CANOE lol. Some say change it- I say Bad Luck.
Any Bond fanatics that might know which one? Already watched Dr No and found out you can't even get old Bond movies free on steaming that I can find. Hmmmm
Quinlan is offline
