She's finally here....... 29' Mirage for restoration. >
Old 04-09-2007 | 07:50 PM
BOOSTEDSCARAB's Avatar
Default the bilge
the bilge
Attached Thumbnails She's finally here....... 29' Mirage for restoration.-mirage-bilge-1.jpg   She's finally here....... 29' Mirage for restoration.-mirage-bilge-1a.jpg
BOOSTEDSCARAB is offline
Old 04-09-2007 | 08:52 PM
Stormrider's Avatar
JC Performance Engines
big single and an xr??
better be careful.
good luck on the project.
Stormrider is offline
Old 04-09-2007 | 09:51 PM
What are you thinking Stormrider...Konrad or Imco...?
Old 04-10-2007 | 07:29 AM
Stormrider's Avatar
I like the konrads... low maint. and w/ a tranny, forward center of gravity. There is a 29 mirage near me that i've got my eye on... its not for sale. its got twin trs and changing to konrads would be easy if / when.
This 29 isn't a small 29 and will take alot of HP to push.
Talk to some of the Pantera guys w/ big singles, they could be of some help. I'd have to say the 29mirage is a good 10-15% heavier than the 28pantera too.
Also, littledcsrodshop is redoing his 28 saber.
Imo, these sized boats w/ twin sbcs is a great option, but the mirage is bigger and seems to do well w/ bbcs.
Old 04-10-2007 | 02:36 PM
MF's Avatar
MF
I think you should go twin..my 2 cents
MF is offline
Old 04-10-2007 | 02:54 PM
why would you choose a XR over a Konrad besides cost??
djtalon is offline
Old 04-10-2007 | 03:51 PM
Stormrider's Avatar
I think the konrad will hook right up to a TRS gimble... at least there is no glass work involved. I'd bet parts are around 12,000 for the drive, which will handle up to 800hp.
Someone w/a cig mistress is doing one right now.
It sure would be nice to only change drive oil once a yr(per biggus) as opposed to every 20-25hrs.
http://www.offshoreonly.com/forums/s...ghlight=konrad
http://www.offshoreonly.com/forums/s...d.php?t=141061
Old 04-10-2007 | 04:23 PM
nocigarette's Avatar
I would stick with the twin option.....A hell of a lot less work and you could make a wicked pair of small blocks, There is no match to the internal geometry of a small block you can pound the rpm, and not worry................It is all about your wallet brother
nocigarette is offline
Old 04-10-2007 | 04:31 PM
northernoffshore's Avatar
In MHO you should go with twin small block 400 c.i. w/ iron 200+dart heads. 230/480 hydrualic cams and 750 holleys. You could put it together inexpensively with good used car parts. Spend the money for the BRAVO conversion w/ steering. You won't need xr's and stock drives w/ minor upgrades will work good. I had ideas about buying the boat you bought ,and repowering it. It should run in the high 80's and be super reliable if done right. I don't like single engine boats that big, and the TRS drives are so Bruried in the water at the current X dimension that speed and handling are effected. High X with 4 blades and bravo drives. You could watch EBAY for small block exhaust. Good Luck with your project. jay ( former owner of 28' cig that I tried many different combinations.)
Attached Thumbnails She's finally here....... 29' Mirage for restoration.-cig3-3.jpg
northernoffshore is offline
Old 04-10-2007 | 04:38 PM
Mine was a project also no power, no interior, no drives or gimbles. The pic of it black is when the old owners had it. good luck.jay.
Attached Thumbnails She's finally here....... 29' Mirage for restoration.-cig3-1.jpg
