Kaama Seals Needed
Old 06-09-2008 | 09:31 PM
don
Default Kaama Seals Needed
Who has the 3 seals at the output shaft, 2 oil and 1 water, that I can get fast? I put the housing back together and noticed the seals where missing. Who has them in stock that I can order them. I can not find the numbers but it is the only seals at the tail shaft before the prop.
don is offline
Old 06-10-2008 | 11:04 AM
Don Call Me 5197912790 I Have Some Here Or I Can Give You The Part Numbers. They Are Readily Available. Bruce
BOATMAN302 is offline
Old 06-11-2008 | 08:36 PM
don
Default Hay Bruce
Hay Bruce how are you doing. I had lost your number when my phone died and took all the numbers with it. I had just remembered that Jay sent me part numbers with the boot. Clipper had all 3 and they are shipping them overnight to me. The next crazy thing is someone stole my props and I am $^**(^$#$^*( To say the least. How can I find 2 props and how many arms do I loose for these. They were 17x 24's SS#731L and SS#732R KME794 and KME795 if this helps. What can I do now Bruce?
don is offline
Old 06-13-2008 | 04:40 AM
1CE
don, try scott or cathy mander @ 850-875-0381 / see add#12473 they are in quincy, florida look's like they may have a set of 17 x 23 4-blade props which should work well 4-u with your 18% over drive set up OR try randy @ cobra power @ 305-893-5018 in n. miami, florida / see add# 10084 looks like he may have a try and test program too ! good luck 2-u ps: u-need the 19 spline long hub props like an o'l #3 merc.
1CE is offline
Old 06-13-2008 | 04:44 AM
1CE
Bruce, dude how are ya doin ? will give u-a shout soon ! J -
1CE is offline
Old 06-22-2008 | 11:54 AM
Why not put out the part #īs here ?
MikeyFIN is offline
Old 06-23-2008 | 04:56 PM
1CE
Mikey, what else do u-need ?
1CE is offline
don
15
06-13-2010 10:17 PM
mjb
Cigarette
4
09-20-2008 06:41 AM
don
Drives and Lower Units
3
01-13-2008 06:53 PM
alj
0
09-11-2007 09:14 PM
Hot Boat
1
07-30-2004 07:57 AM
