Im a ####in sucker and pissed >
Old 03-12-2011 | 08:05 PM
Default Fixx
Originally Posted by fasttoys7619
I have two right hands on the boat now, what kind of gains would i get if i did switch to c/r set up ? i know it would eliminate torque steer, but would i gain any significant speed?, more speed? , thanks ,
you wont gain any speed but it will take the lean out of the boat..
FIXX is offline
Old 03-12-2011 | 08:50 PM
ChristianGott's Avatar
handling, both high speed and around the docks, will improve.
I disagree with fixall. If c/r drives don't improve speed, then why do all twin engine race boats run them?
c/r drives can work together to lift the boat or hold the boat in place (prop rotation). there are many aspects to consider, but generally speaking the c/r set-up is more efficient at propelling the hull forward because the drives work in conjunction with the hull and the strakes, not against it.
.02
c
ChristianGott is offline
Old 03-12-2011 | 09:25 PM
Sydwayz's Avatar
Forum Regulator
I saw a complete Alpha on the Richmond, VA Craigslist last week, in the Boats section.
Sydwayz is offline
Old 03-14-2011 | 08:58 AM
Give me a call.
Tom Mitchell
Cobe Marine
410-255-9488
TMITCHELL is offline
Old 03-14-2011 | 09:26 AM
rchevelle71's Avatar
Definitely go for the SEI, I run one of their lowers on my outboard, good piece. As for the C/R, I dunno, prolly handle better.
rchevelle71 is offline
Old 03-14-2011 | 10:27 AM
I know of a pair of c/r alfa ones are for a $1100 a piece all redone
26MartiniMan is offline
Old 03-14-2011 | 10:28 AM
if it helps
Old 03-14-2011 | 11:45 AM
Originally Posted by Velocity Vector
He said it was ready to bolt up he didn't say it would work after it was bolted up. There is a gray area in there. You just bite the bullet and move on brother. Alfa's are cheap you will find one. SOrry you got the shaft and the drive didn't.
+1, He may not of known they needed work.
TexomaPowerboater is offline
Old 03-14-2011 | 12:05 PM
SS930's Avatar
The marine told him the seller knew the drive was shot. Sounds like the guy was just a POS.
SS930 is offline
Old 03-14-2011 | 12:47 PM
Originally Posted by TMITCHELL
Give me a call.
Tom Mitchell
Cobe Marine
410-255-9488
One of my favorite places.
f_inscreenname is offline
