gettin the old bird together
#31
He's making way to install that 454...setting up for a Bravo install in the F3.
I got my Bravo Transom assemblies in today and cut grass also...school over next 2 weekends so I won't get anything else done.
#32
timing chain cams on both engines and valvetrain installed and adjusted .. need to tack weld my oil pump pick ups and buy some intake bolts.. thats the next step take some more pics once thats on.
#34
jason ans sprink. you both talk about the fact that it isn't worth the price of the parts when done and you will just buy a better-newer hull. save the old pre-alpha housings so you have something to give away with the old hulls. you won't have the heart to junk them. this way somebody else can put 350-alphas back in them cheap and use the rest of your work. and you'll know your old boat is still ok...
#35
#36
we speak as in if it ever happens.. chances of me upgrading to a newer hull who knows.. i doubt it.. but theres always that option of pulling my rebuilt stuff and swapping if something happened to the 255
as far as it not worth it its worth every dime to me when done as my family will get to enjoy it and theres not that many around these parts.. good idea and agree with ya..
#38
1 Post
fixx
@ jayson,,did the boat oe have I 6's in it? what is your center to center measurements on the center of the gimbal bearings?..
#39
This is an old Smokey Yunick trick from the '60's. I have tacked them in or used epoxy.
#40
yes the 2 original pumps i pulled out of the 454,s where tacked on all the sbc,s i used to rebuild to use as race enginesdid not have the pickup welded from factory.. i always welded them on just 2 good tacks will do.. gonna try to get mine done tomorrow been busy with other things...
