newb with Python 24/7 >
Old 08-13-2012 | 08:44 AM
I actually just picked up a 21p 3 blade cleaver style off my local craigslist for 150 to try out. Not sure if im headed in the wrong direction with the cleavers? They seem to be working ok... I also read abou the nose cone not being needed at my speed and its actually a pain because of the reduced clearance on the trailer but i would guess its a pain to remove
dsmawd350 is offline
Old 08-13-2012 | 08:54 AM
It is a pain to remove. So obviously add more power in all seriousness, do some work with the trim. I really think unless the motor is tired, you should be able to see 57-59mph with the right prop and good trim. If you found a cleaver, run it. It's trial and error mostly and I've never had your Python, but different boats like different props. If my math is right, your slip #'s are right around 10%, so it sounds like the cleavers are working, but you'll know better as you get the trim right and run the 21P prop. Let us know how it turns out
machloosy is offline
Old 08-13-2012 | 10:22 AM
My PYthon liked the Mirage plus prop. I tried a Mirage, Bravo, and Hydromotive and the Mirage plus worked best for my boat. I was running a different set up than you because I had 500 hp and a 1.36 drive ratio but the hull liked the mirage plus the best.
cdail28590 is offline
Old 08-13-2012 | 09:23 PM
Cool boat. That was my first go fast. I think I also ran the 3 blade mirage props. Boat runs great a 60+, have to get it on the pad to get a good ride out of it. I was at 71 ish with 390hp 502. Some hydraulic steering would be a huge improvement in handling.
TexomaPowerboater is offline
Old 08-13-2012 | 09:42 PM
It has hydraulic steering. Whats on the pad trimmed and riding good.on the back of the hull?
Old 08-13-2012 | 09:44 PM
You wouldn't happen to be from Cincinnati? Swore I saw that boat on the river this weekend, looks good
Z06vette1 is offline
Old 08-14-2012 | 06:33 AM
Yep i put at Schmidt every chance i get lol
Old 08-14-2012 | 07:57 AM
DirtyMoney's Avatar
Do yourself a favor and get a 23p mirage plus with the 330hp 454 it should run right at 70 with that set up.
DirtyMoney is offline
Old 08-14-2012 | 09:36 AM
Sweet im gonna start looking around. Be nice to pick up a used one
Old 08-14-2012 | 09:41 AM
I've seen you out a few times I'm in the purple and white h2x. See you out there Larry
