Scorpion powerboats
Old 01-20-2015 | 09:54 PM
  #61
Originally Posted by SkaterMike82
Use to go there as well back than when my old man had is 28 Cig. The hardware and women that were there was second to none. You use to see all the big hitters there. Those sure where the days but unfortunately after hurricane Andrew in 92 they never rebuilt it. Ever since than until today is still just empty land.
My Dad had a 28 Bertram "El Bravo" in a slip right behind Sundays..
I would take girls out there on the weekend,go to the bar ,come back to the boat,,get lucky and never leave the slip..Those were the days..
HTRDLNCN is offline
  #62
Default Scorpion 37 progress pics
[ATTACH=CONFIG]535962[/ATTACH][ATTACH=CONFIG]535963[/ATTACH]
Dash panel. We made this out of plexiglass. Fitting it up to ensure it fits as we sand and shape the dash. Next week the Tambour door comes in from Tap-ease. Will be interesting to fabricate tracks and jigs to fit it in the roof. See how it goes.....
Attached Thumbnails Scorpion powerboats-image.jpg   Scorpion powerboats-image.jpg
guilderoy is offline
Old 01-20-2015 | 09:59 PM
  #63
Originally Posted by BUP
I remember that 24 Carrera and the 24 Scorpion.
Carrera if I recall made very few 24's so how many 24's did Scorpion make ?
Those 24 boats ran very well in rough water,
it was hard to tell which was what manufacturer between the two at times running on the water.
Humberto( Carrera) made a lot more 24s than Julio did..
The boats were identical except for the color of the bilge..
(If I remember right Julio used red)
[email protected]
HTRDLNCN is offline
Old 01-21-2015 | 10:56 AM
  #64
MidOcean's Avatar
Why are you making the hatches out of wood (To be glassed over I guess) They look pretty good. I would think with your abilities you would just make a set of one-off molds and lay up with a minimal core. Would net you a 1/3 the weight. As far as the vents, I would use sheet aluminum 3/16, punch your vent holes or slots and powdercoat.
MidOcean is offline
Old 01-21-2015 | 11:00 AM
  #65
Originally Posted by guilderoy
[ATTACH=CONFIG]535955[/ATTACH][ATTACH=CONFIG]535956[/ATTACH][ATTACH=CONFIG]535957[/ATTACH][ATTACH=CONFIG]535958[/ATTACH]
Work on the engine hatches. Went with a low profile design . Looking for stainless steel mesh for the air Inlets or a honeycomb design. Any ideas ?
Here is an idea..[ATTACH=CONFIG]535976[/ATTACH][ATTACH=CONFIG]535977[/ATTACH]Plexiglass inserts here,
xxxxxxx1 is offline
Old 01-21-2015 | 12:23 PM
  #66
Good idea. I'm still learning techniques on laying up. Living in the islands resources to new technology and knowledge is limited. Another reason why OSO is irreplaceable. The base and sides are 3/4" the top is 1/4". Laid up in bi axle. It's not heaven at all. It's about 30-45 lbs per side. I'll out a pics of what I'm thinking for the vents
Old 01-21-2015 | 03:51 PM
  #67
https://www.youtube.com/watch?v=0BZJXrR61Nc
awesome is offline
Old 01-21-2015 | 04:26 PM
  #68
Originally Posted by awesome
I like how stable and consistent the 32 handles. More videos please :-)
Old 01-21-2015 | 04:29 PM
  #69
What are you guys thoughts on a highly reliable engine package. The 37 has #3s on boxes. I would like to cruise around 65-70. Reliably
Old 01-21-2015 | 05:24 PM
  #70
MidOcean's Avatar
My 37' Midnight did 70 all day long with HP 500's. I would think it's heavier than your 37. The tradeoff being that you are running though transmissions and SSM's. I had Bravos on mine. Still 65 should be attainable with this power.
MidOcean is offline
