24 x 7 Strake Modification ...
Anyone able to advise lengthening inner strakes on 24 x 7 Excaliber BBC with TRS. I saw a post on OSO stating extend to 6" rearward of CG, but no advice on how to correctly determine CG based on ballast for passengers and fuel. Note: keel pad is filled to match Superboat early splash of this hull. Bow carries better, but still needs more stern lift. Prop is labbed, reduced diameter Bravo1 14.75 x 24. Thanks in advance from those that have done with success !!!
https://www.google.com/search?q=bala...utf-8&oe=utf-8
google your title, then add offshoreonly at the end.
there is alot of info, problem is i think when a member does not resubscribe (depending on how the pics were posted) those pics are gone forever.
the tomas wallin 24x7 modifying strakes bottom thread comes to mind.
Here are some pics I have saved
https://drive.google.com/file/d/0B53...ew?usp=sharing
http://louisville.craigslist.org/zip/5945460340.html
In case you want something else to practice on...
