Back on the water after many years
I'm back in the boating community after probably 10 years, (fishing boat not included)
I just bought a 30' Century Ultra 3, I have no idea about the history regarding this manufacturer The only reason I bought it was the engines and a nice trailer! Twin 454's with 177 blowers, roller rockers, flat tappet cam, dished pistons that's all I know about the engines plus they were originally built by Innovation Marine Drives appear to be SSM#3 but I'm not sure. They are 1 3/4 shaft with 19 spline Upon water test, initial planning was difficult. Really bad cavitation out of the hole Slight cavitation in hard turn on the outside engine but not a big deal Really stable at speed Ran 70mph GPS 4800RPM no trim with tabs flat I'm going to measure the X dimension and try to get gear ratio tonight Any help would be appreciated Thank youhttps://cimg2.ibsrv.net/gimg/www.off...dda3f65d20.jpg https://cimg3.ibsrv.net/gimg/www.off...5543075010.jpg https://cimg1.ibsrv.net/gimg/www.off...31206d62e.jpeg https://cimg2.ibsrv.net/gimg/www.off...7981b2cb9a.jpg |
Welcome back and good luck with the Century. Those motors should produce some nice power.
Those drives look like a SSM 2 to me.
Have fun!! :coolcowboy: |
Yup, TRS upper #2 lower. 2" deeper than a TRS and parts are hard to find. Have a friend that has them on a Chris Cat.
Those engines are mounted pretty high. Should be a fun ride with those engines. |
Thank you
I'm pretty sure these are III's, I haven't seen many pics of 2's 9 1/2" from shaft to cav plate That picture didn't frame them well Yes they are high, shaft is 5" below running surface Did some maintenance last night, it will be out this weekend, Am I missing something regarding engaging the transmission, I put it in gear but it didn't engage. Does it need to be running? I want to figure out the gear ratio, I think I'm missing a bunch of speed with these props https://cimg6.ibsrv.net/gimg/www.off...024f27e654.jpg https://cimg7.ibsrv.net/gimg/www.off...7ac7d7ae5a.jpg |
Originally Posted by resurrected
(Post 4634311)
Thank you
Actually going to be docked at Sauble Beach
More bikinis there! |
I didnt think the #2 had the crescent front lower like these do ?
(Post 4634391)
HaHaHa you know the area well!
| All times are GMT -5. The time now is 12:42 AM. |
