Sonic 27' Outboards
Old 08-06-2025 | 02:15 PM
  #41
Default 27 Sonic
I put up a picture of a 98 225 Evinrude, 120 LBs of comprssion but doesnt start, would this be compativle as far as the power head goes with my 2001 225 Johnsons?
88Spyder is offline
Old 08-07-2025 | 04:28 AM
  #42
That’s actually a ‘99 model, mfg in 98.
That should make it first yr Ficht and if so, it’s a direct bolt up.
They were known for computer problems.
Had a buddy down here w/early ones like those on a fish boat and about 15 mls offshore one would shut down.
Hed stop and fish, it’d cool off and fire right up and take him home.
He found one that was reman’d and it did the same thing.
Twin O/B Sonic is offline
Old 08-07-2025 | 04:31 AM
  #43
I knew the first part and guessed the second part after staring at that deck seam a while, and recaulking one!
Originally Posted by William Diggens
24 Sonic molds were actually the Donzi molds for the 24 Doral (closed deck), and the Pescador (open fish). Open fish deck mold had an insert to convert it to closed deck.
Old 08-09-2025 | 11:15 AM
  #44
Default 27 Sonic
1993-2001 (185,200, 225, & 250HP) Loop Charged Carbureted Engines, w/ Quick Start & S.L.O.W., 6700 RPM Limit
Took Cowl off and snapped a few pictures of the starboard engine,head is off it. The C.D.I unit on it lists it as a 2001 Johnson 225 Carburated Looper engine. Is this correct?
88Spyder is offline
Old 08-09-2025 | 12:09 PM
  #45
Wow
I stand corrected.
evinrude started direct injected as Fichts in ‘98 while Johnsons continued as carbureted through I think 2001 which was their last year for production.
The cowling style on your motor threw me.
I’ve never seen those on carb’d motors before with the louvers in the back.
Most of them anyhow have that style cowling.
I would say you’re in a way better position with carbonated anyhow.
Now you’ve got something. Easy to work on and cheap to get parts for.
i’ve got a good crank if you need one, plenty of rods and rod bearings, maybe even pistons.
You can throw the block in a propane grill and heat it up and pull a sleeve out and put another one back in and save the block if there’s no holes.
Old 08-09-2025 | 12:15 PM
  #46
Mine are ‘2000 225 Johnson’s.
Old 08-09-2025 | 12:28 PM
  #47
PS, post up pixsoif the bad hole.
Now that we know there carb’d, I’ll go back to what I told you on the phone.
on those it’s normally #2 which is port side, top hole.
Check the block for broken head bolts too.
If their salty motors, the inner head bolts like to seize.
Old 08-10-2025 | 05:38 AM
  #48
Wrong again!
I can see by the pixs that the starboard head is off.
Based on that, I’d guess a piston lost a ring locating pin.
That powerpack is aftermarket.
From the pixs it appears very clean and to have not been apart.
Great donor motor.
Old 08-17-2025 | 10:14 AM
  #49
Default 27 Sonic
Finally got the hatch piston disconnected and the hatch open, took a couple of pictures of the engine bay from the inside, Not sure what kind of power the boat had because the holes and base are not what I'm use to seeing
I added a picture of the Armstrong bracket's part number
88Spyder is offline
Old 08-18-2025 | 05:31 AM
  #50
The old, filled bolt holes look to be from orig Gil brackets.
My first 24’ still had them and that bolt pattern looks about right.
Not sure what the small square plates are covering but definitely not an original IO opening.
Id also say the #s on your Armstrong brackets are probably a serial # indicating mfg date of ‘2015.
From what I can see, I’d guess it was born an OB hull.
Look at the stringers a couple feet fwd of transom and see if you see any plugged holes from motor mounts.
