Help with Stringers !
Old 04-11-2006 | 07:45 AM
Default Re: Help with Stringers !
It appears to me to be solid hand laid glass, no coring.
IHTFP is offline
Old 04-11-2006 | 09:24 AM
Audiofn's Avatar
Charter Member #232
Yup
Put your best foot forward!
Audiofn is offline
Old 04-22-2006 | 12:01 PM
You can drill into those areas to make sure they are wet/rotted. It's a ton of work to fix, make sure the boat is worth it to YOU. Do tons of research, make sure it's RIGHT. It also rotted for a reason, you need to fix that also. I used Nidacore for my stringers-it's a polypropylene honeycomb it will not absorb water ever. use epoxy, the secondary bond is much better.
KAAMASCARAB is offline
Boomer35
Detailing, Painting, & Fiberglass
42
03-18-2015 01:13 PM
batty
Excalibur
5
05-14-2011 08:21 PM
superwrench0166
12
08-11-2007 06:59 AM
US1 Fountain
Baja
5
07-19-2007 03:32 PM
pachangalpina
6
08-03-2005 10:40 AM
