Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
glassing engine stringer and transom >
Old 01-27-2009 | 09:19 PM
Thanks for all the info guys. I have decided to remove the stringer completely. The laminated stringer is nailed together and the bottom is in worse shape than the top. I will post pics of my progress if I can get my camera working. As for the replacement of the stinger, do I need to remove the gel coat(or white pigmented resin???) down to the fiberglass hull. It seems the factory just slopped this stuff in on top of the glass around stringers.
jrcavness is offline
Old 01-27-2009 | 10:17 PM
im going to post pics of mine as soon as the snow melts
doing the same thing!
i just cut the tops of my stringers and gutted out the wood.
mine is an outboard version.
part of the job of mine is working around my transom knees
so i can do my transom from the inside of the boat!!!
stevekyp is offline
Old 01-27-2009 | 10:26 PM
Originally Posted by daredevil
Just cut the topcap of and take a chainsaw and grind the wood out ,,leave the outsides (glass ) standing,make shure that u suport under the hull so u will not greate a hook in to the bottom .
After ground out, mix epoxy and paint the inside of the sides from left over stringer ,bond 2 -1/2 inch marine ply would or even 3/4 (depends on size of existing) together and putty in place, then glass the top over and you done.
I could not resist. Chain saw?
You make it sound so simple.
MOBILEMERCMAN is offline
Old 01-27-2009 | 10:29 PM
Hello Jim,,,it is simple ! NO ????
When i watch my fiberglaser do it it looks pretty simple to me.
LOL
DareDevil is offline
Old 01-27-2009 | 10:41 PM
LOL
If it was simple the women and children would be doing it.
Old 01-27-2009 | 10:57 PM
HAHAHA
What else is going on in texas ?
Old 01-27-2009 | 10:59 PM
HAHAHA
Same old. Getting ready for Biloxi.
21 races this year you say?
Old 01-27-2009 | 11:02 PM
YEP,,,,atleast thats the plan,,,,we will see and i will try.
I will be in Biloxi,,,so i finally meet you there.
Hopefully i will not need your help .LOL
Old 02-07-2009 | 11:39 PM
I'm sold, chainsaws are great. Hours and hours chiseling and grinding to remove the transom and stringer. Finally got pissed and got out my chain saw. Being very careful not to gouge too deep, I was able to finish the job in minutes that would have taken several more hours. Of course, I did have to avoid the nails Wellcraft placed throughout the laminated stringer.
Throughout this whole operation, I have found the lack of quality control Wellcraft took in building this boat. The stringer was exposed to the bilge letting any water get into it. Also, the holes that were cut through the stingers to drain water off the top of the fuel tank were never resin soaked. I am very disappointed.
nova26
14
04-04-2008 05:21 PM
CN24
21
11-25-2007 08:06 AM
jez350
65
10-22-2007 08:41 PM
olysan
20
08-08-2007 08:30 AM
VintageOffshoreClassic
11-22-2003 09:44 PM
