Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Is aircraft stripper safe for removing paint on a boat??? >
Old 11-27-2010 | 02:48 PM
Default Is aircraft stripper safe for removing paint on a boat???
will it do a lot of damage to the gel or glass??
302Sport is offline
Old 11-27-2010 | 03:11 PM
carter38's Avatar
They make a stripper thats safe for fiberglass.
carter38 is offline
Old 11-27-2010 | 04:28 PM
ok ill check it out, i have like 10 paint jobs on the boat and would be sanding until next winter haha
302Sport is offline
Old 11-27-2010 | 05:32 PM
johnny g's Avatar
I`ve read on the vette forums that its one of the prefered methods for vettes
johnny g is offline
Old 11-27-2010 | 08:37 PM
carter38's Avatar
This stuff will work.
http://www.jamestowndistributors.com...ct.do?pid=2544
carter38 is offline
Old 11-29-2010 | 08:47 AM
has anybody used it????? have heard varying results???
302Sport is offline
Old 11-29-2010 | 08:51 AM
SS930's Avatar
If you have that much paint on there, I'd probably take it down with abrasives... save yourself a ton of work!
EDIT: There's a media blaster in Millford CT that does fantastic work, I think this is the place:
http://www.amerstrip.com/
SS930 is offline
Old 11-29-2010 | 09:12 AM
ive heard blasting makes it wavy as hell.......everybody who ive talked to that had something blasted regretted it. maybe ive just the heard the bad and not the good????????
302Sport is offline
Old 11-29-2010 | 10:25 AM
SS930's Avatar
A friend of mine owns a body shop. I know he has had a couple of vettes sent out (to them) and has not had an issue. With that said, he primes and blocks everything afterwards to make sure they are wave-free.
Heat is the enemy, so media selection and proper technique is critical.
I can't image removing 33' of ten layers of paint with chemicals... I would think that would take forever. I'd even break out the 36 grit before I tried that!
SS930 is offline
Old 11-29-2010 | 10:53 AM
tried the 36, and i would be sanding till next year....
302Sport is offline
