Stringer!
Old 04-20-2011 | 10:50 PM
Default Stringer!
I have what looks like a single piece of 3/4" plywood for a stringer that holds the starboard side of the starboard motor (BBC) that cracked...
Is this normal for formula? 3/4 plywood to hold that much weight?
How do I replace that piece and achieve more strength... I don't want to run screws thru the hull/ transom?
I pulled the starboard motor tonite and am scratching my head at this point...
mung272 is offline
Old 04-20-2011 | 11:11 PM
cut/grind the old stringer out and replace. post a couple piks so we can see exactly what your dealing with...
phragle is offline
Old 04-20-2011 | 11:42 PM
f_inscreenname is offline
Old 04-22-2011 | 10:21 AM
I cant post pics...
the Stringer is not rotten, just cracked behind the motor mount...
It seems like a poor design, it sticks up 6" above the shelf that goes to the hull side and gives it the strength...
the motor mount is attatched in this 6" area near the top of the board.
mung272 is offline
Old 04-22-2011 | 10:31 AM
Originally Posted by f_inscreenname
X2
fasttoys7619 is offline
Old 04-22-2011 | 10:48 AM
can you post the pics for me?
mung272 is offline
Old 04-22-2011 | 10:52 PM
Do it through free hosting. http://www.imageshack.us/
