Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Squid needs direction on main stringer... >
Old 06-11-2012 | 09:05 PM
glassdave's Avatar
Neno the mind boggler
Originally Posted by dereknkathy
a friend did his. he peeled transom wood off the outer layer of glass hull. left glass attached to boat. cut and fit everything. then when glassing it in he used the transom mount bolts as clamps and alignment jigs. had all orig holes where factory (searay) put them. i'd like dave's opinion on this method...or maybe it is how they all are done?
if you mean they cut the glass from the out side never ever never do this unless it is a small bassboat or low freeboard runabout where there is no other choice. I have seen it done but it is only a technique for very specific circumstances. Sounds like the center board stringer is trashed anyway so it all needs to come out. Once ya get on a roll the bad wood and glass come out no prob.
Skinning the transom from the inside isnt to bad if done right. I will dig out some pics later to illustrate. I think i have some archived transom jobs somewhere
08 OPA High Points Champion
glassdave is offline
Old 06-12-2012 | 06:58 AM
this is where i'm at now
38 X is offline
Old 06-13-2012 | 04:46 PM
So do i remove the fiberglass from the inside on the face of the transom to get to the wood???... take a sawzall to it and cut the whole thing out?....Not sure what the proper directiong to go from here is? I read a couple oder threads and wasn't sure of the steps here...kinda seemed like everyone left the outside fiberglass intact....
38 X is offline
Old 06-13-2012 | 05:09 PM
From what I read, looks like the outer stays intact and we would work from the inside.
WikedLizard is offline
Old 06-13-2012 | 05:45 PM
c_deezy's Avatar
Here is a link to my rebuild thread. First couple of pages show my transom removal.
http://www.offshoreonly.com/forums/b...ld-thread.html
c_deezy is offline
Old 06-14-2012 | 06:22 AM
C Deezy excellent job and excellent post! a lot of great information there, is there any way you could give me a supply list and a layout of how you actually built the new transom? Definitely got the step by step layed out! Your boat cam out amazing!
38 X is offline
Old 06-14-2012 | 07:46 AM
glassdave's Avatar
heres a illustration i did recently for a book on the subject. This is a general layup. I will get more up in this thread particularly a materials punch list. On rough un even transoms sometimes i will replace the CSM with ATC's Corebond.
Attached Thumbnails Squid needs direction on main stringer...-transom-layup.jpg
Old 06-14-2012 | 11:34 AM
this is what i have ordered so far
38 X is offline
Old 06-14-2012 | 12:30 PM
Not trying to hijack the thread but Dave is your book out yet? Would love to buy it if it is.
272bajadriver is offline
Old 06-14-2012 | 12:41 PM
same here
mr3dman is offline
