Transom replacement full vs partial
#42
I used 36-40 grit grinder to prep the glass surfaces and the marine plywood as it's mahogany faced and as such, very smooth. Cleaned the prepped glass with a premium laquer thinner.
#43
Sounds like a very cool project! If you talk to the right folks prior (glassdave) and a few others here, it's not that bad. Worst part is the grinding off gelcoat and glass. Make sure you get a 3m tekk or equivalent respirator and a protective suit (tyvek type or similar). Once the prep is done, it's a lot of fun!
#45
