bolster seat bottoms
Old 04-27-2008, 08:10 PM
Default bolster seat bottoms
Seems my bolster seat bottoms have rotted away. there was a piece of wood covered with fiberglass attached somehow to the foam. Now there is nothing to bolt the frame to . Any help would be appreciated..
34SUTPHEN is offline
Old 04-28-2008, 11:56 PM
Received 1,824 Likes on 909 Posts
I doubt the wood floor was attached to the foam. At least it shouldn't have been. It should glassed in and/or attached to the stringers. Sounds like you need to do some cutting on the floor and then reglass and reinstall some wood encapsulated in fiberglass. That or use some composite or starboard.
Griff is offline
Old 05-04-2008, 12:31 AM
AIR TIME's Avatar
ARE YOU TALKING ABOUT THE SEAT cushion thats gone or the floor of the boat where the frame bolts to?
AIR TIME is offline
Old 05-05-2008, 05:50 PM
jhiguy377's Avatar
sounds like the flip down seats themselves; I re-did mine last year. the upholstery was stapled to the plywood then it may have either been resined over OR covered by a pre-made piece of glass, the old rotted piece should give you a template. best of luck to ya - jeff
jhiguy377 is offline
Old 05-06-2008, 01:55 AM
If he's only talikng about the actual seat, that should be no big deal. Cut new wood and glass and resin over it. That or use some starboard.
Griff is offline
Old 05-06-2008, 09:52 AM
jhiguy377's Avatar
yeah, starboard would be the ticket
31scarab31
Wanted
1
03-25-2008 10:29 AM
Steel Outlawed
Baja
8
12-04-2007 04:01 PM
ls1nova
11-07-2007 05:26 PM
NJThumper
Superboat
14
07-31-2006 08:28 PM
JohnnyMarshall
Fountain
7
05-01-2006 05:38 PM
Quick Reply: bolster seat bottoms
