Winterization-add flushing attachment to Perko strainer? >
Old 10-03-2010 | 08:20 PM
Sydwayz's Avatar
Forum Regulator
Originally Posted by mark s linger
question,if i drain the block first,then use a •Antifreeze Jug with earmuffs ,will i burn the Impeller up while waiting for the antifreeze to circulate thru the engine ?
I hate this method. Yes, you can absolutely burn up an impeller.
I've put up pics and info here on the OSO before. I use the self winterization jug/kit; BUT I added a tire valve stem to it, and I pressurize the jug. It sends the AF right into the pump.
However, I have a fresh water flush system. I hate using muffs.
Sydwayz is offline
Old 10-03-2010 | 08:46 PM
Originally Posted by Elite Marine
Guys -
Dont forget, the best way is to run the engines so the stats open, then drain the blocks. Then add your antifreeze. Otherwise you are diluting the antifreeze with the water in the engine and actually raising your freeze point and burst point.
Also the safest bet is the -100. Spend the few extra $$ and save yourself and yuor engine!!
I found a perko strainer for my AC unit that has the ball valve as part of the top cap......I just wanted the top but couldn't find where to buy it seperately.....haven't done anything with it yet.
watch movies online
daviddwilson is offline
Old 10-04-2010 | 07:02 PM
I open the cap on my strainer and stick the hose right inside to run the engine. To winterize it, i pull off the lowest hose on the engine and drain it to get as much water as possible out. Then I start the engine and keep dumping the antifreeze in the strainer til it blows good pink out the exhaust. I usually run about six gallons thru. I kind of do it over kill. I keep my boat in heated storage but try to play it safe in case heat went out.
specialk is offline
Old 10-05-2010 | 03:59 PM
I just drilled and tap the top of the strainer and installed a street 90, which I plumbed to the new fresh water flush fitting installed on the swim platform.
Attached Thumbnails Winterization-add flushing attachment to Perko strainer?-34-pc-024.jpg
Treads is offline
Old 10-05-2010 | 05:47 PM
Guys -
Im with you Elite thats how i do it.
ext2gtx is offline
Ran-Dom 32
10-16-2008 03:58 PM
88Fount33
1
07-28-2006 04:18 PM
Kentz
Powerquest
19
06-10-2003 05:45 PM
rtn137
5
05-28-2002 07:30 AM
Julio
Powerquest
3
02-22-2002 07:34 AM
