square heads or oval on 500hp >
Old 12-22-2008 | 06:47 PM
Default square heads or oval on 500hp
Newbie question here does the 500hp have square or oval on the intake?
thanks guys
oldschoolfan is offline
Old 12-22-2008 | 07:38 PM
The 500hp 502 has square port heads and intake according to Dennis Moore's book. If unsure, check! I wound up buying a square port manifold for oval port heads once! What are the head casting numbers?
Ghostrider is offline
Old 12-22-2008 | 08:18 PM
This is the HP500 intake. Changed the overall look of it just a little, but it is the same.
First one on the list. 4150 carb and 9.800 deck square port.
http://www.jegs.com/p/Dart/756849/10002/-1
If you want one that is a little better in my opinion. Use the Edelbrock 454-R
http://www.jegs.com/i/Edelbrock/350/2902/10002/-1
jeff1000man is offline
Old 12-22-2008 | 09:44 PM
They look the same to me ???????
Jeff can u build my new raceengine ?????
DareDevil is offline
Old 12-22-2008 | 09:47 PM
Not if you want to finish the race.
You are more than capable.
Old 12-23-2008 | 11:51 AM
thanks guys
The stock Merc 500HP uses GM rect port heads.
Griff is offline
Old 12-24-2008 | 01:00 PM
all 502 stern drive engines use rect ports as far as I know..there were a few early inboard oval port 502's in the mid 90's but are very rare and cannot find them anymore...I tried everywhere when I repowered my gibson....Rob
ezstriper is offline
Old 12-25-2008 | 06:03 PM
I agree on the use of the 454 series Edlebrock. Question: How would the oval port version work with the rect port heads? Any increase in port velocity?
ROTAX454 is offline
Old 12-25-2008 | 06:50 PM
That could work with a "sort of stock" engine.
Old 01-09-2009 | 08:59 PM
thanks guys
The mpi motors had intake 2.219 valves the Hp 500 had 2.250 valves all square port. I have two sets of the hp500 heads in the swap shop section.
formula 382 sr-1 is offline
