Indicators sticking
Old 03-15-2009 | 12:21 PM
Default Indicators sticking
One of my indicators will go out till about 4 on the panel, but hangs up there. I took the actuator on the drive apart, and cleaned it, but still sticks a little. Would replacing the spring inside the actuator help? They are prob pretty weak by now. It doesnt take much pressure to "push" the indicator down with my finger once it hangs up. THanks!
MILD THUNDER is offline
Old 03-15-2009 | 12:25 PM
Oh, also, I was thinking of adding a type of throttle return spring on the backside of the indicator panel, keeping pressure on the cables "out" in order to take up any slack in the cable??
Old 03-15-2009 | 12:44 PM
the problem is usually not the spring,as the cabels age,they have a tendancy to drag,sooner or later,you will need to replace the cabel.
mike tkach is offline
Old 03-17-2009 | 07:28 PM
I had the same deal on my 29 outlaw. I cleaned the actuators good and even tried to lube the cables. It got better but still would stick. Ended up replacing the cables and all is good now.
blefever is offline
Old 03-17-2009 | 08:04 PM
offthefront's Avatar
Cables .....get'r Done
offthefront is offline
gaffer
Do It Yourself, Boating on a Budget
3
08-26-2008 12:41 PM
sandcraft
Nordic
5
08-26-2008 10:12 AM
RBake
8
04-06-2004 10:35 PM
Fountainclimber
3
09-02-2003 07:50 AM
epeek
8
06-16-2003 07:22 PM
