Help with starter wires!!! Pics attached >
Old 10-04-2009 | 08:11 PM
If the wire thats hanging has a small eye on it (cant tell from pic) it goes on small stud on the outside of starter sol. There are two small ones. the one closest to block is the yellow/red one that energizes sol to crank eng. the one on the other side sends 12 volts to coil when cranking to bypass resistor wire. some systems dont use this wire but they are still in the harness.
tms1155 is offline
Old 10-04-2009 | 09:20 PM
Originally Posted by kyboy1020
Pulled the starter today and took it to the tester... Solenoid was bad... So I replaced it with a duralast gold that matched it identically and has a life time offer. Autozone only charged me $50 for itand has life tine replacemennt so figured it was worth a try... Installing it as we speak
I'm guessing its not a marine grade starter with spark protection then??????
Griff is offline
Old 10-04-2009 | 09:41 PM
No sir.....I got it installed and it works well...what is the spark protection for? I just wanted to make sure it was a heavy duty one with all metal internal gears....
P.s. That wire was for my corsica silent choice exhaust... I got in unhooked and wired open so no need for it
FuelinAround is offline
Old 10-04-2009 | 09:45 PM
Throttle Fever's Avatar
Smile
You want a marine type starter assembly. Gas fumes sort of linger low in the bilge. So any spark makes for a h@ll of a boom. Glad you got it running. A+
Throttle Fever is offline
Old 10-04-2009 | 10:02 PM
Ok did some research... Thanks griff... I'm going to use this starter to winterize with and try and purchase a new one before next season. Anyone know a good source to purchase a 454 starter from?
Old 10-05-2009 | 02:46 PM
Anyone got a site for mercruiser starters for me?
Old 10-06-2009 | 02:10 AM
Had good success here:
http://bpi.ebasicpower.com/c/MER10J-...for+Mercruiser
saw this one on another site:
http://stores.channeladvisor.com/db-...arine/Inboard/
wet_rat is offline
Old 10-13-2009 | 08:53 PM
sunchaser796's Avatar
Unless its rated for marine use, give it back to them and I'll send you a pine coffin..
sunchaser796 is offline
