Under Hatch Mirrors
Does anybody know where you can get mirrors for under the hatches? and can you get colors? Any ideas?
mirrors
I went to a plexiglass shop and ordered mirrored plexiglass and it worked fine. They also have a wide range of colors.
I can get it for you from my supplier, I'm close to you give me a call 540-786-8111, Rob
I got mine from a place up here in Cincinnati called GE polymer. A 4x8 sheet was a little under a hundred bucks. Then i cut it close to size with a table saw and fine tooth blade. Router or jig saw works good too.
Originally Posted by Potomac Fever
(Post 3032832)
not saying you can't however be careful with the jig saw. i've used one when in a pinch however you can screw up quickly that way. if you do make sure the film is still on it and double up with some extra masking take along the cut areas and also tape off the bottom of the saw surface to prevent scratches. use a real fine blade. a plexi cutter is only a couple of bucks at the hardware store and works well. belt sander for finishing.
how would you attach this?? epoxy?
502ss whats the name of the stuff you bought from the website posted?
who ever you decide to get it from make sure its polycarbonate,its heat resistant and way stronger! :)
| All times are GMT -5. The time now is 01:13 AM. |
