Msd 6m
Old 01-28-2010 | 03:16 PM
Default Msd 6m
Thinking of putting a MSD 6M and maybe a "blaster" coil on my boat, its a 95 454EFI, has anyone done this? is it pretty straightforward? I have wired a pile of 7AL3's and MSD10's on previous drag cars, but, didn't know if there was anything different in a marine application?
Thanks!
Michael
n20michael is offline
Old 01-28-2010 | 03:57 PM
Thanks!
Michael
Very easy. They come with full instructions and they also have all the instructions on their web site if you want to check out before buying. Here's a diagram from Teague Marine Tech Tips section on their home page.
http://teaguecustommarine.com//store...s/pn6460-1.pdf
picklenjim is offline
Old 01-28-2010 | 07:18 PM
Great, thanks! I looked at the PDF file and was curious? I am using the OEM distributor not the MSD one, do you still hook up the wires to the distributor the same way? If I use the stock coil is it the same as well?
Thanks!
Michael
Old 01-28-2010 | 08:08 PM
They show in the instructions that come with the box how to hook up to different distributors and coils. They also include a bag of different connectors and such for making the connections.
Old 01-29-2010 | 12:33 AM
Why do you want to run a MSD on a stock motor?
rdoactive is offline
Old 01-29-2010 | 12:57 AM
Just to clean up the idle, a little better economy, ran SEVERAL stock motors with 6A's and 6AL's and always had good luck, I guess the same reasons most people run them.
Old 01-29-2010 | 07:28 AM
If you're having rough idle, cabon fowling on a stock efi motor you've got a problem that an MSD would only be a bandaid for.
Same with a blaster coil, if your firing voltage requires 60kV, you've got other problems.
You might want to look up reliability issues with MSD in the tech section too.
