Best option for more speed >
Old 03-08-2010 | 03:19 PM
Question Best option for more speed
I have an 27' Fountain Fever , stock 502mag efi with a bravo 1drive with 240 hrs . Fastest speed under ideal conditions is 69mph but it can run 65 mph consistantly . Overall i'm happy with the boat as is , that is until my buddy passes me in his aluminum river boat with a jet drive . It just don't look right having an ugly ol' campertop jetboat whooping a performance boat like a Fountain .
Am I best to go with a new engine & drive combo or can the 502 and bravo 1 be upgraded and still be reliable ?
I get so many differing opinions from friends that I'm not sure what to do . Ultimately I would like to find the best setup for the 27' Fever , to get it up in the mid to high 70's or better .
8luglogic is offline
Old 03-08-2010 | 03:47 PM
LAriverratt's Avatar
try the fountain forum..they can hook you up...with at least 10 different opinions but really...someone there can get you going in the right direction.
LAriverratt is offline
Old 03-08-2010 | 03:49 PM
Will add about 150hp and 10 mph. This is not mine.
http://www.offshoreonly.com/classifi...o33073-en.html
You will NEED external hydraulic steering if you do not have it.
Griff is offline
Old 03-10-2010 | 11:04 PM
i agree with griff,as a rule of thumb,it takes 15 hp to go 1 mph faster.the best,most reliable,and cheepest way to get the additional 150hp,is supercharging.the sidemount whipple will get you the xtra hp you are after.
mike tkach is offline
Old 03-11-2010 | 08:48 AM
I think this is crummy advice but everytime I ask the question what's the best way to get more speed I'm told "get a faster boat".
Sunshadow is offline
Old 03-11-2010 | 12:54 PM
Super Charger gets my vote...
wjb21ndtown is offline
Old 03-11-2010 | 02:33 PM
Figure out your budget and work backwards from there.
Supercharger bolts on without a complete engine redo is a joke. Doing so will result in a complete engine redo in about 20 hours at best. stock engines are setup for performance on pump gas ad have too high a compression and will detonate with anything but a pund of boost or so, and the heads arent setup with the heat blower makes from the factory. - you can follow the advice of guys that have done it , or give it a shot yourself and see what happens.
It takes a series of comprehensive upgrades to get a boat to start picking up speed reliably.
first thing is exhaust- this is the basis all of the upgrades have to stand on - your stock exhaust just blows. You'll pick up a bit everywhere with an exhaust kit and ECU program engine this upgrade will allow you to reap the benefit of further mods.
Try a top end kit - real heads, new intake, cam and ECU, you can usually pull at least a 100 to as much as 150 ponies out of a stock mercruiser with a god top end kit and exhaust.
Raylar makes a good kit- and those guys are a hoot as well.
After than you'll likely need steering upgrades.
UD
Uncle Dave is offline
Old 03-11-2010 | 07:04 PM
502 Mag is 415 hp right? Thats pretty good speed you are getting out of it. If you want to go faster, try a procharger. PM arcticfriends, as he had a pretty solid running 502 back in the day.
Old Navy is offline
Old 03-12-2010 | 11:19 AM
I had a Procharged 7.4 MPI! Weak engine internals. Ran the snot out of it for 4 years 200hrs. A smaller size boat. Some say I got lucky. Something will eventually break. I lost a head gasket but the engine did hold together. Still was worth to me. It was a lot cheaper than the 600hp naturally aspirated motor I'm running now. My .02 cents.
steveh1209 is offline
Old 03-12-2010 | 11:36 AM
Wahoo ATV's Avatar
Racer
Talk to Tyler Crockett. He has developed a new blower system that will fit under you hatch and uses your efi.
Wahoo ATV is offline
