Engine Coupler?
Old 04-04-2010 | 02:08 AM
Originally Posted by 515/271FORMULA
Would that also apply if you have solid mounts (race mount)?
There is very little movement with race/offshore mounts. You can tweak it a very very little bit if needed by loosening the bolts, but usually it does not get out of alignment either. If its way off for some reason, then the mounts need to be redrilled. I would also be looking for a reason as why the alignment is off.
Griff is offline
Old 04-05-2010 | 08:30 AM
Originally Posted by Sunshadow
As long as you're pulling the drive check the u joints.
already replaced the u-joints , they were falling apart. Ha !
Thanks for all the replies. Will keep updated.
NOPUN is offline
Old 04-05-2010 | 04:33 PM
ive seen couplers come loose and also flywheels come loose, u might want to retorque
outlaw26 is offline
Old 04-05-2010 | 09:44 PM
Tinkerer's Avatar
Exhaust flappers in the Y pipe. Is the sound metalic?
Tinkerer is offline
Old 04-05-2010 | 10:24 PM
Strip Poker 388's Avatar
Rob
I red locktite it all
Strip Poker 388 is offline
Old 04-06-2010 | 07:04 AM
I had a similar noise and it was the upper gears in my drive.Remove the top cap and have a look just in case.Hope it's ok.
Cookin is offline
Old 04-06-2010 | 08:10 PM
thats stuffs woths it weight in gold
outlaw26 is offline
Old 04-07-2010 | 02:42 PM
Saftey wire the exhaust flappers closed and they'll stop making noise.
Sunshadow is offline
Old 04-08-2010 | 12:26 PM
Ha, that might work !! I didn't even know it had exhaust flappers.
Rechecked the engine alignment and it was perfect .
still makes that metalic/clinking sound at idle tho. can anyone tell me what an engine coupler might sound like , or other synthoms when going bad?
NOPUN is offline
Old 04-08-2010 | 12:55 PM
Exhaust flappers!!!!!
Pure Energy is offline
