Engine Coupler?
Old 04-02-2010 | 03:33 PM
Default Engine Coupler?
Hello all,
Ok, I just got thru replacing the gimble bearing, and bellows and all that. When I started the engine I'm hearing a metalic rattling noise that varies with engine speed. ( sounds similar to a loose torque converter on a car) . anyone have any ideas ? I'm thinking engine coupler or broken flywheel . What say you ?
P.S. this is a 1990 chaparral 2300sx , 7.4L bravo 1
NOPUN is offline
Old 04-02-2010 | 08:03 PM
did you use the Alignment tool before putting thr outdrive back on?
Sunshadow is offline
Old 04-02-2010 | 09:09 PM
if the drive is all the way up,it will make a loud rattling noise.
mike tkach is offline
Old 04-02-2010 | 09:29 PM
Well, I called myself using the alignment tool
The drive shaft slid into position with no problem
how would one adjust the alignment if it were off?
NOPUN is offline
Old 04-03-2010 | 01:25 AM
You need to use the alignment tool to make sure everything lined up properly. Poor alignment is the reason for bad couplers and worn out u joints.
You adjust the alignment by adjusting the engine mounts.
Griff is offline
Old 04-03-2010 | 07:09 AM
ballon78's Avatar
ebay has alignment tools for 30-40 buck works great bought one a few weeks ago. here are several machine shops that make them on there.
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 04-03-2010 | 11:44 AM
I'll try the alignment again, but, for my luck , that would be to easy a fix !!!
NOPUN is offline
Old 04-03-2010 | 12:13 PM
Exhaust flappers??
Pure Energy is offline
Old 04-03-2010 | 06:29 PM
As long as you're pulling the drive check the u joints.
Old 04-03-2010 | 09:42 PM
Would that also apply if you have solid mounts (race mount)?
353Formula is offline
