Merc Trim pump Problems
Old 04-05-2010 | 09:15 AM
Default Merc Trim pump Problems
I just re-installed my alpha and trim cylinders. Everything was completely drained.
The trim pump won't pump. I have it filled with oil, the hoses are currently disconnected just to test it. It makes a whine noise when I hit the switch but nothing comes out. Is there a trick to getting this thing primed?
olysan is offline
Old 04-05-2010 | 09:57 AM
OLYSAN,i just had the same thing,i replaced the lines from the pump all the way back.the pump is high pressure,low volume,it takes a while to get the oil threw the lines,keep trying,it worked for me.
mike tkach is offline
Old 04-05-2010 | 10:51 AM
Thanks for the reply Mike. I disconnected the lines at the pump just so I could see if it was pumping anything, and it's not. I would expect to see something there pretty much immediately. ??
olysan is offline
Old 04-05-2010 | 11:54 AM
i agree,if nothing coming from ports on the pump,their is sonething wrong with the pump.
