Port side trim limit switch. >
Old 04-05-2010 | 08:14 PM
scottw's Avatar
Default Port side trim limit switch.
I'm rebuilding my transom and while doing so I am replacing both trim switches. Starboard switch for gauge still had the pluc connectors on it so that was plug and play. The trim limit switch on the port side had a broken wire on the outside so it was jumped out on the inside and wires were cut so I have no clue where it plugged in. I would like to make things work properly so my question is where do the trim limit wires tie into? What should I look for?
scottw is offline
Old 04-05-2010 | 09:03 PM
PAST DUE's Avatar
there should be bullett connectors somewhere around the trim pump wiring that is where the trim limit switch should plug in.
PAST DUE is offline
Old 04-06-2010 | 07:52 PM
scottw's Avatar
Thanks Past Due. It was right there infront of me. I thought it was it but wasn't sure. If it were a snake it woulda bit me.
scottw is offline
