wiring dui distributor
I got a new dui distributor and was wanting to know where to hook the shift interrupt switch wire to. On mine when the switch is closed its just completing the circuit to ground. Its a green and white wire that ran to the back of the distributor on my thunderbolt iv ignition. Am i supposed to run the green and white wire to the tach term. on the dui dist. Will that momentarily kill the motor when shifting out of gear. I dont want to smoke my new ignition. Has anyone hooked one of these up with an alpha drive. Any help will be app.
I thought of that too, but grounding the coil will result in a spark. If that happens at the wrong time, you could have a nasty backfire.
I got a hold of performance dist. and they told me the same thing . To hook the cut out switch to the tach term. on the dist. Seems to be working just fine it dosent get any simpler than that does it. Two wire hook up. thanks for the feed back
