Seat rebuild...How to...?
Old 07-10-2010 | 10:23 AM
Default Seat rebuild...How to...?
My seats have decent vinly but the bottoms of the backs are rotten where they meet the base. I plan to pull off the vinyl and rebuild the frames then hopefully pull the vinyl back over them.
Question: How do I make the curved back piece? Anyone have any suggestions or good ways curve the back around the bottom? Thanks.
Hondo Jet is offline
Old 07-10-2010 | 11:09 AM
Good luck removing the vinyl. You usually damage some of it in removal.
Buy a good tack puller at a fabric or upholstry shop to remove the staples and try not to rip anything. The vinyl may be attached internally in the seat too.
1/4" plywood can flex pretty good. If it wont make a sharp enough curve, you can cut half way through the plywood every inch using a table saw then curve it around an arched piece. Glue and fasten it tyo the arched piece.
rdoactive is offline
Old 07-10-2010 | 11:24 AM
3 ways with wood..
1. force it
2. steam it
3. lots of almost penetrating slits with a table saw
phragle is offline
Old 07-16-2010 | 06:16 AM
done it a few times, carefully take it apart, just rebuild just like they did it..pretty strait forward when you take apart, once wood done, paint it with a couple of coats of good ext paint...they probably left the wood bare...
ezstriper is offline
Old 07-17-2010 | 04:59 AM
Fountain4402's Avatar
your vinly will probably come apart plan on the extra cost of replacing that specially if they glued it
Fountain4402 is offline
Old 07-17-2010 | 10:50 AM
A heavy coat of thined epoxy to soak in then a couple regular coats and never worry about the wood again.
phragle is offline
Old 07-17-2010 | 01:20 PM
on my bolster seats the outside is round in the back of the seat. once i pulled the vinyl and foam off it was 3 small pieces put together. good luck on removing the foam not the vinyl.
demag67 is offline
Old 07-17-2010 | 01:55 PM
northernoffshore's Avatar
cut at 45degree angle to the outside and sand the shape edges
northernoffshore is offline
Old 07-17-2010 | 02:11 PM
Default a different approach
I did the same thing and got tired of the whole wood thing
Went to the local plastics shop bought a couple of sheets of PVC
used the wood as templates and then just screwed and glued the frames together........ just my 2 cents
inxs01 is offline
Old 07-18-2010 | 01:30 PM
when i redo my seats again im going to the pvc. the price is only a couple of dollars more a sheet then marine plywood, and is half the weight plus it will never rot.
demag67 is offline
