Ok I took drive toe measurements..Help me decipher what to do >
Old 07-21-2010 | 07:18 AM
Originally Posted by US1 Fountain
Can't tell, do you have hyd steering?
Be surprised if you didn't have an inner tie bar w/o hyd steering. That would put all steering forces one the 1 drive tiller arm/gimble ring.
Go by the red and yellow line to set your toe.
Are you talking about exterior steering?
FuelinAround is offline
Old 07-21-2010 | 07:20 AM
Ted G's Avatar
Originally Posted by kyboy1020
Where is the inner tie bar located? I was assuming it was connected to the outside of the drives but I'm curious now. There is definitely only one tie bar on the exterior between the 2 drives
You need to look at the steering arms inside the boat at the transom, the bar should be attached between them if it's there.
www.cbpba.com
Ted G is offline
Old 07-21-2010 | 07:42 AM
Originally Posted by Ted G
Just run your tie bar in about an inch and you are good. you may have to open up your inner tie bar if you have one. 1/4" toe in is good.
Inner tie bar ????? you must be looking at a different picture BIG Daddy
KY give me a call it'll take you all of 10 mins to get her set
Old 07-21-2010 | 08:46 AM
birdog's Avatar
Without Hyd. steering...It better have one !
birdog is offline
Old 07-21-2010 | 02:58 PM
Talked to Bruce at sonic. He said yet set everything at 36. And you only need interior tie when you run over 80. Same with exterior steering, not really necessary until over 80
Old 07-21-2010 | 06:01 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I wouldn't let Bruce touch my boat then if that is his opinion. According to your 1st post with dimensions, it will be impossible to set everything to 36" as Bruce suggest. I suggest don't talk to Bruce no more.
BTW, I'm talking about hyd steering... which uses rams on the outside of the boat, then you do not need the inner bar, which is on the inside of the engine compartment. Not to be confused with power steering.
US1 Fountain is offline
Old 07-21-2010 | 06:51 PM
Here was his email and it was 35in not 36 sorry guys
"Hey Josh….Bruce here from Sonic Boats…….We most always set the drives at 35”"
I assume he is talking about the prop shaft which would coincide with that Ted G said about running them in about an inch. I would absoluitely love to have external steering like you are talking about. I know Bruce has been around sonic a long time so I am hoping that this is the correct answer for me.
Old 07-21-2010 | 06:53 PM
I am going to swing by and get a pic tonight but I beleive there is no kind of bar of any sort between my transoms from the inside. I need to look and verify this from inside the ol engine compartment.
Old 07-21-2010 | 07:06 PM
There has to be !!!!!!!!!!!!!!!!!! otherwise u would only steer 1 drive ..lol
DareDevil is offline
Old 07-21-2010 | 07:11 PM
Ginger or Mary Ann?
35" sounds better. That will give you right at 1/4" toe in.
Run'r.
