Bending SS Rubrail
Old 08-21-2010 | 04:48 PM
Originally Posted by KEVLARKAT32
The most important step is to layout and have the least amount seams on side and NOT have a hole fall on bend , that will make it easy to kink . Any and all outside bends you simply screw RR to boat and when you get to a bend put cardboard on paint to protect and work rail around , a rubber hammer can help . Inside tunnel I made a wood form of tunnel where rail fits ( subtract with of rail x - 2 ) screw rail to wood form and bend around corners of form . If you need a pic I still have form , hope this helps . One more tip I also used long straight edge @ seams to insure there was no droop
Thanks for the info! I made a form of the bow and the rail formed perfect!
Maritime_Eng is offline
