Low Oil Pressure!!!!
#42
IMO unless you plan to make any other performance upgrades to this engine such as head work, exhaust, intake, carb, roller rockers than going to a roller cam set up is going to be a big expense, probably $1200+ and will have little if any gain. Probably only see a couple mph gain. If everything else is going to be left stock than I would just stay with a hydraulic flat tappet cam. Their fine cams and last a long time as long as you break them in properly. Lot of them running out there. Then all you would need to do is rebuild the short block. Probably save ya at least $900 bucks on the cam alone. You would also save money on having new springs set up on your heads. Just saying your going to spend a lot of money for the very little gain you "might" see.
Just my 2 cents which in this economy isn't even worth a penny.
#43
I am going with roller rockers and i already had headers with thru hull. I have been hearing so many different things. I was told that its hard to get the flat tappet broke in because of temp. i just want to build the motor so it will be dependable. If I can get a few more hps in the build then great. Im happy with the performance of the boat the way it was. Just want the motor to hold up.
#44
Have you talked to Bob RMbuilder ? If you have the budget I would definatly get your cam, springs and lifters from him. It will be an awakening for you on how to build a engine. I gained 5 MPH with his setup and I already had a preformance flat tappet with similar duration. It also idles better and is much quicker.
#46
#48
ok i have decided to go with a comp cam p#11-451-8. here is the specs.
Brand COMP Cams
Manufacturer's Part Number 11-451-8
Part Type Camshafts
Product Line COMP Cams Xtreme Marine Camshafts
Summit Racing Part Number CCA-11-451-8
UPC 36584038535
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,200-5,800
Intake Duration at 050 inch Lift 230
Exhaust Duration at 050 inch Lift 236
Duration at 050 inch Lift 230 int./236 exh.
Advertised Intake Duration 284
Advertised Exhaust Duration 290
Advertised Duration 284 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.547 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.547 in.
Valve Lift with Factory Rocker Arm Ratio 0.547 int./0.547 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible No
Grind Number CB XM 284HR-12
Valve Springs Required Yes
im ordering the k-kit. but im swaping the srings out with 150# springs.
im also adding rocker rollers. does anyone forsee any problems with this setup?
Brand COMP Cams
Part Type Camshafts
UPC 36584038535
#50
I use to think this was bulll****t. That's until I tore an engine down after not changing lines and cooler after a blowup and saw terrible bearings with tons of crap run through them. The engine still ran fine but it was subjected to much debris and its life was going to be short if I didn't tear it down again for other reasons.
